will this work???
Yes but it wont shift right why would you want to anyways? Just spend the $20 and get a cheap short shifter or just chop the top off your shifter and tap the thread lower.....
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
'00 FBP Si
Sebring rule in effect
'00 FBP Si
B16aracer explain to me how you will fuck up your tranny by getting a short shifter or chopping the top sorry but you are wrong. By getting a short shifter you reduce the throw by choppping the shifter down the throw is not affected(the bottom shaft of the shifter is still in spec but the top shaft is shortened to create better placement. Sorry you should know whom you are correcting before you try to make a fool of yourself I can have and do internal tranny work explain to me how it will fuck up the tranny? Learn more about cars then get back to me......gear ratio/throw is not affected thus tranny is not affected.
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
Oh yeah almost forgot I have an ls shifter if you need it.....among many others I AM LSMAN....ask around
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
Guest
Posts: n/a
looks like u need to learn about car
not b16a
Dont make me laugh
'00 FBP Si
'00 FBP Si
Originally posted by hybrid 98 ls
Can I use the stock shifter from a 98 civic ex to put into my 98 integra LS? thanks
Patrick
Patrick
