Motor, Tranny, etc...
Had my 240 hatch, pulled the motor to put it in my coupe, sold the coupe shell, I have laying around the ka24de motor, transmission, driveshaft, full stock exhaust, alternator, starter, wire harness, sway bar(for a 240), i need it gone asap, best offer can take it. 727-678-8904
I called @ 9:01 lol... $100
nah it hasnt, and id like to sell everything at once, im not asking a arm and a leg for this stuff, just need it gone asap, like i said, best offer can have it all and im in clearwater/largo, when the motor and everything was in the hatch it ran fine, but wasnt running stong because it had a blown head gasket and a missing knock censor, pulled the motor to put it in the coupe, discovered the head was bad, cams were bad, a motor mount was messed up, but i got a different head, cams, head bolts, and motor mounts, and i also have the knock censor for it now. so everything should be fine for whoever gets this off of me.
OOOO, sooo this is a motor with a blown headgasket. Your first post is somwhat misleading. You may want to put some of the key info in your first post so ppl do not think this is a drop in swap. Ill let you know though, If this ends up being cheap enough i may get it all.
-Julien
-Julien
tranny is good, will need a new clutch, and the pistons do have some wear when they were hiting the valves, got a new head, cams (dual cam motor), motor mounts and head bolts, the motor was in the hatch, it ran fine, other then it missing a knock censor and a blown head gasket, i have the knock censor but didnt replace the head gasket cause i was planing on rebuilding the whole motor but lost interest in finishing it.
