How to make side markers flash WITH turning lights
So today I was driving on 275 north and saw a clean ass white rex looked like it had a JDM front but anyways I got off and I was turning left they were turning right and their turn signals and side markers all flashed at the same time.. on mine the side markers and the turn signals flash one then the other like side, corner, side, corner, etc. How can you make your side markers flash WITH your corner lights so that everything is together as one? Thanks
what he said.. but this only works when you do it the way honda intended.. which is side marker off all the time and on only when the turn signal is on.. thats how mine is.. i have the side marker directly connected to the turn signal...
Mine are on all the time. I wouldnt mind if they blinked when the turn signal was on but i guess you cant do that.
^that's because they're wired to direct power, not a relay or switch, or even the blinker wiring harness.
-Winston Churchill
-Winston Churchill
They were on the car when I got it, I like them on all the time I just wouldnt mind if they blinked.
Hmm. You could rewire it and use a relay. Splice the terminal for the switch into the blinker wire. That way whenever power is sent to the blinker, it's sent to the side marker as well. But I don't think the side marker would ever be on other than when signaling so idk how that works...
omg just buy the stanley wiring kit
Stanley OEM Honda Side Markers+Harness 92-95 Civic EG:eBay Motors (item 190342204686 end time Dec-14-09 23:51:06 PST)
'like omg'
why waste the money?
