View Full Version : Clear headlamp lenses --
Bluballz
06-07-2009, 10:18 AM
I know this has prob been done before, I remember reading it. However i can't seem to find it. My headlights have a foggy coat I am trying to remove. I can't recall what grain of sandpaper to use, or if it was a mothers product that I need to remove the film. Any info would be good :D
oldschool98
06-07-2009, 04:08 PM
Best thing to do is completly sand them with 600~1000 and clear them with Urethane clear. I do them for people around here.
Bluballz
06-07-2009, 05:34 PM
thnx. I picked up a 3m kit that had everything in it. sanding and polishing.
oldschool98
06-07-2009, 09:51 PM
It will not last though. The plastic will continue to deteriorate.
Largo 5.0
06-08-2009, 05:34 PM
Does the clear prevent the light from oxidizing again? I would assume it would act as a protective coating and extend the life of the light.
oldschool98
06-09-2009, 07:23 AM
Yes. Stops all UV from getting to the plastic surface.
Pancake
06-09-2009, 10:38 AM
yeah it does, but even that over time will fade..... why else do cars get ashy? lols
a much much cheaper method to restoring headlights is to just wetsand from 600 up to 2000. then borrow a buffer or use plastic polish by hand. looks brand new, make it last by waxing every now and whenever like you do your car.... IF you do that to your car :-o
MikeR
06-10-2009, 06:49 PM
I wouldn't bother going through the trouble buying the material and doing it yourself.
I found a place where I got it done in Riverview for only $40
The place is off of Gibsonton Rd exit. behind the Raceway. Its called Restore Your Ride.
Powered by vBulletin® Version 4.1.4 Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
Content Relevant URLs by
vBSEO 3.6.0
