Sponsored by: CARiD
how to install dry kit
Old Mar 20, 2009 | 04:23 PM
Bori300's Avatar
Bori300
Default how to install dry kit
well i just picked up a Zex dry kit to use on my ls-vtec build.. And i was wondering how to install it i have never installed a nitrous kit before.. I have everything need to install it all the switches and all.. And was wondering how to go about it.. O and its going in a 93 eg coupe any help is appreciated thanks
TR 5th Gen Civic CREW Member # 17
TR "Old Skool DA" Member #55
Old Mar 21, 2009 | 02:32 PM
Shadow_Stallion's Avatar
super simple. run the nitrous bottle to the line to the solenoid. the solenoid to the nozzle.
now the electrical should be simple as hell too. run the arming switch on one side to constant power, and the other side to the relay. ground the relay. then plug in the solenoid wire to the wire. and constant power to the relay.
the ground wire on the solenoid- wire one side of the button to a good chassis ground, and the other side to the ground side of the solenoid.
when you press the arming switch, it sends power to the solenoid, when you press the arming switch, it connects the ground in the circuit, opening the solenoid and making you go fast
Old Mar 23, 2009 | 08:20 AM
Bori300's Avatar
Bori300
thank you sir
Old Mar 23, 2009 | 03:29 PM
no problem, i just had to install a wet kit, and do the wiring the hard way
Old Mar 29, 2009 | 06:17 PM
DANGERANGER's Avatar
Shop Bitch
If you need help let us know, we've done dozens
