PDA
View Full Version : mix and match rear air setup...bad idea???
Boats N' Hoes
10-23-2008, 10:44 PM
i came across a pretty good deal on a air lift 3 link for the s10. its a bolt on kit and just lays the axle against the frame. heres a link
http://www.easystreetair.com/manuals/75612.pdf
the question is could i use that and my SD notch so the truck will lay out? any info, opinions ect would be great.
thanks
kris
killerMikeD
10-24-2008, 12:08 AM
if ur notch is big enough i dont see why not.
Boats N' Hoes
10-24-2008, 12:15 AM
its just the typical SD notch they say it lays a 22...in on 20s....i plan to do the bag over axle
mexicant
10-24-2008, 11:20 AM
YEAH man the notch should not interfere with the link set up. is the link bolt on or weld on? you also need to make sure the notch is big enuf to lay out
Boats N' Hoes
10-24-2008, 02:44 PM
the notch is the suicide doors s-10 notch. they say itll lay a truck on 22s so im pretty surethe notch is no problem. i just want to make sure the 3 link will lay out.
thanks guys
DANGERANGER
10-25-2008, 09:42 PM
Yeah as long as its installed correctly you will have no problems, a notch is a notch, its the install that counts. We are an Air Lift dealer and they make awesome stuff, so if you got a great deal on it then cool, but if not the SD is better in my opinion
Boats N' Hoes
10-25-2008, 10:13 PM
like im getting it for 150 is that a good deal? i plan on NOT using the airlift helper bags and just doing a bag over axle. im bagging the truck my self with the help of my uncle (which all have bagged hot rods) the quality of work they put out is top notch....made several cover on super rod and super chevy. any way thanks for the advice and looking out i really appreciate it.
DANGERANGER
10-27-2008, 11:26 PM
You most likely will not be able to do a over axle setup due to their panhard bar configuration. Besides those bags ride awesome.
Boats N' Hoes
10-29-2008, 09:37 PM
well the setup doesnt come with the bags to begin with...plus if this link wont achieve frameage....ill just keep saving and get one that does.
