Breaking Up Sr20det
Old Sep 25, 2008 | 07:10 PM
Nismosil40zx's Avatar
Default Breaking Up Sr20det
Hey Everyone I have a s13 sr20det, mods are
Sc61 turbo top mount external gate (18psi)
Greddy Intake manifold
780cc injectors w. walbro 255
z32 MAF
FMIC 3IN tubing
BC 264 cams I/E
Enthalpy tune for 20psi 8000rpm limit
SAFC2 Just to use a rpm and put full in certain spots where it need it
The problem I having is its breaking up around 6000 to 7000 A/F is good around 10.9 or 11.2 Sometime it does it and sometime it dont. I was thinking those 18 year old coils might be going. Anybody have an Idea?
Thanks
Old Sep 26, 2008 | 04:40 AM
UnderStitching's Avatar
Dissapointed with TR
I would think it was a spark problem. Does it jerk when it hits 6k or do you feel the power drop out from under you gradually?
Old Sep 26, 2008 | 12:19 PM
Default ...
it just drops and cuts out loss of power
Old Sep 26, 2008 | 01:11 PM
Epstein's Avatar
Retired
I'd stick some new BKR7EIX's in there at 0.028" before I dumped a bunch of money on new or aftermarket coils.
Old Sep 26, 2008 | 01:42 PM
I just put a set in. Always have an extra set worth the shot. I also have a interstate battery samething as the odyssy wonder if that battery could be messing with the charging system
Old Sep 26, 2008 | 01:50 PM
Epstein's Avatar
Retired
It's probably just a dying coilpack, then. An SC61 at 18psi, while making a ton of power, really isn't near the limit of the stock coils.
Old Sep 26, 2008 | 01:57 PM
what are the coils good to.
Old Sep 27, 2008 | 08:02 PM
Any ideas on when stock coils max out
Old Sep 28, 2008 | 07:03 AM
Epstein's Avatar
Retired
Enthalpy ran them up to 25psi and 540whp. Others have touched 600whp. Once you start adding things like B&M NewVolt / XS Eng. Power Pack type voltage amps it goes up from there.
Old Sep 28, 2008 | 11:59 AM
yeah im only making 400+ im going to check the resitance in the coil just to see put thats polly not going to tell me anything if its intermittent.
