Hello all.
I am upgrading my differentials to include Detroit Lockers (Suretrac) (http://www.eaton.com/EatonCom/ProductsServices/PerformanceProducts/Products/Differentials/Suretrac/index.htm) front & rear on my F-250.
I am trying to decide who gets the work...
My top two candidates are "4 Wheel Parts (http://www.4wheelparts.com/)" and "Northside 4x4 (http://www.tamparacing.com/forums/www.offroadmonster.com)".
I may also require pinion work..... got a howl coming from the rear diff.
What first hand experience have you had?
What recommendations do you have on finding a place to do the work?
Thanks,
Cecil
Patrick
08-28-2008, 05:11 PM
Call 4 wheel parts and talk to Will. He's a good guy and will hook you up. My buddy had 4.30's put in his truck and Detroit locker put in at the same time. They done a great job and he's had zero problems with them.
Another option is Gear Works. They are located in Clearwater. Another guy I know had 4.30's put in his truck there and says nothing but great things about them.
Gear Works
1410 N. Hercules Avenue
Clearwater, FL 33765
Phone: 727-784-0452
I've heard a lot of bad things about Northside. But then again, you always hear good and bad about all shops.
88RedRex
08-28-2008, 06:15 PM
ive had great experience's with 4 wheel parts, i might be taking my truck up there for a few goodies to get put on if my money comes in at the right time
jta
08-28-2008, 07:43 PM
I have got parts from Will @ 4wheel parts, if you go there talk to him. I would give fl-krawler (http://www.floridajeepers.net/profile.php?mode=viewprofile&u=1097) on FL jeepers a call if I needed the work done. He builds some sick rides. I have seen some of his projects in action and they have all been top notch very nice work.
Cecil
08-29-2008, 12:26 AM
So far we are looking at the following mods / fixes / upgrades:
If you don't mind a lil bit of a drive, call Jesse @ Farmboy Fabrications. He does great work. He's done all the work on my vehicle and is a stand up guy. No one will touch his labor prices and he's a small business guy.
His cell # is 910-367-8762.
Tell him Patrick sent ya.
Patrick
09-08-2008, 10:58 PM
whatever happened with this? You always seem to post up needing help and never reply back what happened with it? lol
Cecil
09-09-2008, 09:13 AM
LOL, yeah.... I'm good like that.
I've been working with both 4-Wheel Parts and Northside 4X4 thus far, and as of a couple of days ago, Extreme 4X4.
I am not driving the truck until I get it fixed.
However, I really need to get it fixed.
I've been using the Jeep as my daily driver and let's day it leaves something to be desired..... like A/C!
Will hold off on the tires for a little while.
Want to see how well the lockers work before I decide on which tires to get.
If the lockers work well, I will stick with an A/T tire.
If the lockers do not work well, I will move to a more aggressive mud tire (and possible wider rims and some cut-out fender flares).
I have a few other things I want to do to the truck as well:
Banks Innercooler
Mag-Hytec trans pan
and possibly a brake system upgrade
Cecil
09-09-2008, 09:16 AM
Cecil,
Where is Jesse located?
jta
09-09-2008, 10:09 AM
the difference the lockers will make is like the difference between 2wd and 4wd. it really is night and day.
Patrick
09-09-2008, 10:55 AM
Ft Myers
Like I said, little bit of a drive but he's always been great on pricing.
IwinUlose
09-09-2008, 11:19 AM
Cecil, Were doing our best to get the you the best prices and best service as possible. To be honest i think with Truetracs you will be fine. I have True-tracs in my 97 F150 with 4.30's with 265/75/16 BFG rugged trail T/a . I have buried the truck up to the doors and still have been able to get out.
Cecil
09-09-2008, 11:29 PM
file:///C:/DOCUME%7E1/CSTRIN%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpghttp://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_126000.jpg Detroit Truetrac
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_125992.jpg
Smooth operation
Performs open until needed
Fully automatic limited slip The Detroit Truetrac was the first helical gear differential ever introduced into the automotive aftermarket as an Eaton brand. It remains the leading helical gear-type limited slip differential in the industry. Detroit Truetrac's proven helical gear design eliminates the need for wearable parts, resulting in maintenance free traction recognized not only for its toughness, but its smooth and quiet operation as well.
Proven design, low cost and effective performance all make the Detroit Truetrac limited slip differential the ideal choice for a wide variety of vehicle applications. No maintenance - Just Traction.
Cecil
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_126001.jpg Suretrac
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_125999.jpg The Suretrac performs like an open differential under “normal” conditions, and automatically transfers torque to the wheel with better traction when conditions warrant. The Suretrac limited slip differential responds instantly to torque feedback, anytime, at any speed. Suretrac reduces one wheel spin-outs from disabling the vehicle and also limits shock loads on drive train components to extend their life.
Suretrac transfers torque flow by combining conventional type differential components with additional friction packs. The special coated friction plates react to movement between the gears and the differential case. The wheel with the least traction is locked and power is transferred to the wheel that has the best traction.
Two rugged and durable versions are available. The Suretrac GA series consists of standard type differential gears and spider shafts, a series of friction and reaction plates, and actuators. The plates are compressed by the actuators as they separate due to the ramp angle mesh with the spider shafts.
The Suretrac GS series is similar, but doesn’t use actuators. The friction and reaction plates are compressed directly by the gear teeth separating forces. A great number of plates are used to achieve this traction control performance.
Suretrac differentials complement Eaton’s rugged NoSPIN brand locking differentials and the reliable helical gear type Truetrac brand torque biasing differentials.
