PDA
View Full Version : 92 toyota pickup motor question
ZrexC
08-22-2008, 01:48 PM
i gotta 92 toyota 4wd w a blown 22re and i got a like 86 22r. the intake and exaust are not interchangeable but the heads seem to be. anyone got any info on this? thanx
sl2racer
08-22-2008, 02:38 PM
i think the head will bolt to the 22re block but not sure if your fuel injected intake will work.
ZrexC
08-22-2008, 03:26 PM
toyotaforums says the timing chain will be too long but idk
sl2racer
08-22-2008, 03:59 PM
i always wanted to do the 22re block with the 20r head.
ZrexC
08-22-2008, 11:08 PM
would it work?
ZrexC
08-23-2008, 06:35 AM
im tryin to do a 22re head on a 22r block...ttt
Hellaslow
08-23-2008, 01:32 PM
you can put the efi mani on a carbed 22r. thats a common conv. for us 22r guys.
just swap the whole 86 engine into your truck and bolt up the efi stuff... it works!
V8TITAN
08-24-2008, 02:01 PM
to put a 20r head on a 22r it has to be machined to fit, if you want to talk to someone here in tampa who knows what hes doing, go to toyotaminis.com his user name is grounds and some numbers after that but he posts about everyday and just search around because the forums are dead there and it wont be hard to find his posts. Tommorrow we are going to cam my 22r with a stage 2 trd and 38 weber carb.
V8TITAN
08-24-2008, 02:03 PM
oh I thought he wanted a 20r head on his 22r.... well If your 86 motor runs just throw it in your 92? if you really want it efi just swap the manifold and your good
ZrexC
08-25-2008, 08:18 PM
bolts dont line up...im not sure what year the carb on is
JDM PUNK
08-27-2008, 12:24 AM
Try TTORA.com Lots of info on this site.
ZrexC
09-05-2008, 09:20 PM
UPDATE:: the 22r has a hemispherical head so the pistons will hit the head cuz the 22re isnt hemi... gonna try to swap pistons and see how it goes...
prymerintegra
09-30-2008, 11:56 AM
my truck was efi then converted to carb .... there is a mechanical fuel pump on the side of the 22r head so im almost certain you wold have to change the head to back to efi ,like i did to go to carb..
