PDA
View Full Version : V-DUB A/C and cooling fan ISSUE HELP!!
TURACE24
08-13-2008, 10:18 PM
I'm working on a 2000 V.W. beetle, the cooling fan runs continuously with the car off, and the a/c compressor doesn't run, and the system is fully charged. So there is some electrical problem coming from somewhere, anyone aware of an issue with these cars in relation to this. I'm under the impression it could be the cooling fan module. but im not too sure...
Any help would be greatly appreciated
Thanks
BisquitMan
08-14-2008, 08:35 AM
Thanks
The fans should kick off eventually. I know mine run if the car is hot or if the A/C has been running even when the car is turned off. If the compressor isn't running, it could be the compressor itself.
TURACE24
08-14-2008, 09:02 AM
they do not shut off.. theyll run all night till it kills the battery..
BisquitMan
08-14-2008, 09:21 AM
Then I think you guessed right, probably an electrical issue.
VR6exxy
08-14-2008, 01:37 PM
Fan Control Module
TURACE24
08-14-2008, 02:01 PM
thats what i was thinking, i ordered it today
thanks!
TURACE24
08-17-2008, 11:35 PM
WTF!! i changed the cooling fan module, everything worked perfect for about 5 minutes. fans came on, ac came on, everything was tip top.. Then everything stopped, a/c shut down, so did the fans, now, nothing, checked all the fuses.. all good... HELP!! anyone got any ideas??
