PDA
View Full Version : rotary help!!
silverhonda217
08-07-2008, 01:02 PM
in the past few days my car has been just shutting off on me with no warning it starts idles and runs fine sometimes it will drive with no problems at all but then it will just shut off i let it sit for awhile pump the gas and it starts up i am still new to the rotary i have no clue plz help :(
tito_12a
08-07-2008, 01:41 PM
are you letting it warm up ?
silverhonda217
08-07-2008, 10:37 PM
ok back to the subject i always let my car warm up it drives great it just shuts off it did it to me today i barley made it home iam getting fuel and spark
by the way what is up with the hyundai guy
Captain Fap'n
08-08-2008, 03:51 PM
enough. keep it TECH or take it to pit road. i am cleaning up this thread, do NOT post in here again unless it it directly related to the OP.
1sleeping7
08-09-2008, 09:54 PM
What does the car idle at?
EnsenCorp
08-11-2008, 12:40 AM
What motor? Was this the same guy that had the Corolla with the 13b in it? Too lazy to look. Here is the factory service manual to help you out if you can't get a good answer here:
Index of /main/factory_service_manual (http://www.teamfc3s.org/main/factory_service_manual/)
EnsenCorp
08-11-2008, 12:43 AM
You know, sounds like a problem I used to have. Test your fuel pump out, it's all in the FSM. I changed mine out, and no problems.
It usually cut out on me if I was really getting on the throttle, but it could be a multitude of problems, really
Niburu
08-12-2008, 08:50 AM
I got a pm from Silverhonda over the weekend basically it was the fuel pump and alot of crud in the fuel tank. so he is replacing the pump and filter and cleaning the tank out.
Personally i think he is lucky it's carb if any of the crud had made it past the filter the injectors would be toast right about now, plus carbs are a bit easir to clean out even if you get them clogged with crud.
EnsenCorp
08-12-2008, 10:48 AM
True that
Rx7_guy
08-14-2008, 04:31 PM
Check all main grounds...also check plugs and lines and filters.
PRORACING
09-02-2008, 11:49 PM
sounds like its just off timing a lil bit, does it shut off while ur driving or when youre at a light???
95Ride
09-08-2008, 10:35 AM
if you ever get to where you cant do fix it or need used parts call jeff and mazdtech (813) 874-0937...worked for mazda for years and now has his own rotory specialist shop...the guys knows his shit and is a nice guy as long as you dont try to bs him and get on his bad side.
813kr$
09-15-2008, 09:30 PM
sounds like a bad coil, when they warm up the stop working until they cool off again, then they work.
when it dies on you just pull the plug wires off the coils and turn the key to try and start, you should hear and see the snapping of the coils sparking. if one is sparking and the other is not. It should be the leading one out, cuz the engine will run with only the leading working, but not run if only the trailing is working. so if this is the case swap coils around, to get you home or the parts store. The trailing plugs are mainly for emissions to clean up the left over un burnt gas. good luck!
