PDA
View Full Version : Some of you may have seen this on EG so dont bother. Battery issue
VR6exxy
08-04-2008, 07:03 PM
I have a vr6 OBDII and my battery will not stay charged. I have to jump my car every time i need to start it. Could it be an issue with a ground???? If so i know all the grounds under the battery which other ones should i check. If you dont think its an issue with a ground what else could it be? Once I jump it it stays running so i dont think its an alternator issue. Thanks for the time and the help
Brad
Caan
08-04-2008, 07:38 PM
Why can't it just be the battery? If you want to spare yourself some grounding problems down the road, head over to Interstate Battery on Busch and have them make you a few shielded grounding cables. . . Tranny to frame, block to frame, battery to frame.
VR6exxy
08-04-2008, 08:41 PM
Yea all my grounds are good. Its the battery. Thanks for the suggestion too.:thumbup:
G-Magoo
08-05-2008, 01:57 AM
Busted out the multi-meter?
VR6exxy
08-05-2008, 08:06 AM
I checked all my grounds and they were all good so i took the battery down to autozone to get it tested and its shot. Gotta find a new one today.
Madness
08-05-2008, 12:14 PM
this happened to my friend..
is your alternator still working??
727 GST
08-05-2008, 01:06 PM
lower your car more so it's closer to the ground. that will help
G-Magoo
08-05-2008, 01:27 PM
yeah just use your oilpan as a ground.
