PDA
View Full Version : running firestone f9000 BOA setup??
Boats N' Hoes
07-29-2008, 11:43 PM
just wondering if i can use the f9000 sleeve in a bag over axle application? from what ive seen alot of setups are bag under behind axle. my bridge kit is def bag over axle, just curious if these will work?
thanks
kris
DANGERANGER
07-31-2008, 08:55 PM
Yes you can use any bag over axle. With the F series Firestones you will just need more room above the axle as these bags do not compress as far as the double convoluteds. Also you will have to add a bumpstop and suspension limiter when using these bags. Overall this style bag rides the best in most rear setups.
