View Full Version : Rear knuckle question
ryan_west06
07-27-2008, 05:00 PM
will Rear STI hubs slide into wrx knuckles???
WhiteGhost2.5
07-27-2008, 07:53 PM
5x114 sti hubs? They will if you get them machined to fit.....hehehe
Josh
ryan_west06
07-28-2008, 12:45 AM
the Axles and hubs are off a 04 sti those are 5x100.
My problem is getting the hubs into my 05 wrx knuckles. I havent really messed with it yet but looking at it yesterday it didnt seem like the hubs would slide into my knuckles.
I know the bearings are different!
LDadrenaline
i believe i had to get new knuckles... at least for the front i did, pretty sure the rear as well. MrAnlet would know for sure
ryan_west06
07-28-2008, 12:47 AM
no i dont need fronts! The wrx axles will slide into the 6 speed!
LDadrenaline
07-28-2008, 01:05 AM
yeah but R180s >>>>>>>>> R160s.... and STI bearings >>>>>>>>>>> wrx bearings
ryan_west06
07-28-2008, 12:35 PM
huh....
I have a R180 with STI axles.
When you did your 6spd swap did you need the rear STI knuckles????
no, they will not. youll either need to get them machined, or get STI knuckles to go with them. you also might need to worry about some of the ebrake stuff too if you go with the knuckles. But i cant remember exactly.
WhiteGhost2.5
07-28-2008, 03:19 PM
just pull a wrx hub and have machine shop turn the STi hub down to the size of the wrx hub and then press into bearing. Not too hard to do thats for sure.
Josh
ryan_west06
07-28-2008, 05:37 PM
okay will trying to find a place around here to do it is gonna be hard!
how much material does that leave on the hub though?
ryan_west06
07-28-2008, 05:44 PM
Im getting mixed signals on the knuckle issue!
I wont need the e-brake assembly mine will work!
Im waiting on the rotors and bearing kit to come in from Autozone!
ryan_west06
07-28-2008, 05:45 PM
I honeslty cant say much untill i fit the bearing kit onto the hub and see how that slides into the knuckle. With the bearing kit off it has plenty of clearance. ill let you guys know!
mranlet
07-29-2008, 10:44 PM
No, they don't
You're going from R160 w/ axles to R180 w/ axles, right?
Wheel bearing diameter and width, spline shaft diameter and hub shaft for the R180 are all significantly larger, enough to the point that I'm not so sure that there is enough material in the R160 rear upright to even support an R180 assembly once it has been machined out...? Your best bet is to use R180 rear knuckles.
What are you planning on using for rear brakes?
ryan_west06
07-30-2008, 12:00 AM
im looking to get the brembos. I have new STI rotors, bearings and hubs :)
Need knuckls now! grrrr
LDadrenaline
07-30-2008, 02:09 AM
all subarus rear brakes are too small ;)
blacksti
07-30-2008, 02:19 AM
shit i went from 140 to 0 pretty damn quick the other night
LDadrenaline
07-30-2008, 02:39 AM
thats funny, didnt know you went all the way down to 0 on the track....dont know any other place you would be doing 140 either
blacksti
07-30-2008, 02:50 AM
airport run way
mranlet
08-03-2008, 04:12 AM
Cool. Don't bother with trying to adapt R160 brakes to R180 hubs - you have to grind off the Ebrake shoe pin and all sorts of other garbage...
ryan_west06
08-04-2008, 01:15 PM
lol im gonna try and avoid that but if all else fails i might adapt them!
Content Relevant URLs by
vBSEO 3.2.0 RC5
