View Full Version : DEumb Question about 273 cid engine
GoingLikeHwannabe
08-08-2001, 01:17 PM
I know that the 273 is a non poly a emgine but if i order a 4bbl intake for a 318 will it work? The reason I am asking is I ran into some trouble a while back putting a 4bbl intake of an 85 318 onto a 68 318 bolt holes didnt line up and I dont want to spend 300 bucks to find out it wont work.
Thank You
Lori
Clint
08-08-2001, 01:43 PM
it should work fine since like you said the 66 318 was the poly 318 also known as wide-block for obvious reasons... the 273 318 340 and 360 can all use the same intakes & heads for the most part... (using 340/360 heads on the 273 may require cutting for the valves)
Content Relevant URLs by
vBSEO 3.2.0 RC5
