View Full Version : Alltrac problems
Alltracfreak
06-28-2008, 12:37 AM
when i give it full throttle it breaks up any suggestions???? and i got a check engine light
RTA Supra
06-28-2008, 08:00 AM
Check engine light will give you a hint ;) Find out what code it's giving and go from there
Ricksta
06-28-2008, 06:41 PM
i think the dealer charges 100 bucks to hook it up to thier machine. i was having all these problems with my old celi back in the day and it ended up being a bad sensor. funny how so many things can go wrong just over something something small.
jriggs
06-28-2008, 07:01 PM
if your throwing a cel go to autozone they will check the codes for free and help you clear them
RTA Supra
06-29-2008, 10:58 AM
I'm assuming it's not OBD-II so good luck with having Autozone help
MR Dizzle
06-29-2008, 06:33 PM
ignition problem !! change plugs, cap, rotor, fuel filter, all that basic crap. should be fine after that
Alltracfreak
06-29-2008, 11:29 PM
i think the intake cam is off by a tooth cuz it runs best if the dizzy is advanced all the way otherwise the throttle response is slow as balls. should i advance the cam gear or retard it??? yeah its 88 so it def aint 0b2 its obd 0. toyota should have the dode reader and read it for 100 bucks????????
tissimo
06-30-2008, 03:23 AM
CelicaTech - powered by vBulletin (http://www.celicatech.com/imagearchive/bgbonline/bgb.php#4th) should be your new best friend
christo4_99
06-30-2008, 07:34 PM
check your fuel filter...
Spetertoi
07-05-2008, 06:29 PM
Happy is the man who learns from the misfortunes of others. / \./ \/\_ I Hand You __{^\_ _}_ ) }/^\ A Rose... / /\_/^\._}_/ // / ( (__{(@)}\__}.//_/__A___A__wow gold (http://www.comegames.com/)____A__wow gold (http://www.comegames.com/gamecy.jsp)_A______A____ \__/{/(_)\_} )\\ \\---v----V-----V--Y----v---Y----- ( (__)_)_/ )\ \> \__/ \__/\/\/
Toyota Terrorist
07-06-2008, 09:44 AM
I am in lakeland and if you want to make the trip I have a snap on scanner. Hit me up as I work weekdays so only weekends are free to do it.
Content Relevant URLs by
vBSEO 3.2.0 RC5
