PDA
View Full Version : question (ball joint?)
ZrexC
06-24-2008, 02:38 AM
92 cavalier...when ur goin down the road, if ur turnin the wheel to right its makin a clunking noise...that would prolly mean its the pass side ball joint, correct? lmk thanx
Mars_302
06-24-2008, 03:23 AM
sounds more like cv shaft to me
wmskateteam
06-24-2008, 11:26 AM
depends, CV would click
ball joint can pop in out, also tie rods could have play
if you jack the car up (unloaded) and the wheel is loose left to right than it's usually a tie rod
if you jack it up under the control arm (loaded) and you can pop the wheel up and down it's the ball joint
if you jack the car up (unloaded) and the wheel is loose in all directions it's the hub
ZrexC
06-24-2008, 12:25 PM
its not a cv...thanx
Jono
06-26-2008, 07:37 PM
Your sure it's not a tire rod end or a bad strut or shock? also like the guy said above you can always jack the car up and try to shake the tire if it wabbles you can take it from there.
I have the same problem in my car right now but all my shocks and struts are messed up!!
