PDA
View Full Version : Almost there...Bagged s10
Paul
06-16-2008, 06:08 AM
Heres some of the stuff I have gotten for my 95 s10...
I still need to start getting all the stuff for the EDC..I am NOT going to use the compressor, tank or valves...I do have 6 SMC 3/8's & I still need 2 more RE8's..
http://img508.imageshack.us/img508/9775/kids020fe4.jpg
It will be after the summer b4 I start getting every thing for the EDC...
Just Dave
06-16-2008, 09:02 AM
Why aren't you using the compressor or tank?
Paul
06-16-2008, 04:28 PM
Why aren't you using the compressor or tank?because I am going to build a EDC for my set up..
killerMikeD
06-16-2008, 05:47 PM
sweet, ive had my edc sitting on my tool box for a year now! lol
Boats N' Hoes
06-16-2008, 06:17 PM
sweet man! looks like youre well on your way, good luck with the build.
DaMF'inBoss
06-16-2008, 06:33 PM
Damn it man your truck sure has come a long way since I first saw it. G/L on the bag project. question is the photo of your truck in your sig photochopped?
badhombre
06-16-2008, 10:14 PM
but you will still need a tank. you may be able to take that one off that setup and just use it. it will save you $50 of buying another one. is that one of those AIM plug and play kits? also what link is that? looks like a KP. I can tell just by looking that it uses the factory spring perches. be careful dragging, becasue the link bars are usually the first things to go. unless you get the fix kit from suicidedoors. you will however be very happy with the ride quality of that setup with the re8's on a lever. my buddy has them on his SD 5link with shortened lift bars. he gets 14" of lift(limited by shocks) at about 50 psi. and he rides with the rollpan about 1" off the ground and even going over the roughest roads he never bottoms out. that truck rides sooo smooth. 8's are tough to fit in the front. can be done, but it will be ALOT of cutting. I'm running 7's on mine without any complaints. locks out the arms at 90 psi, and ride great with the front anywhere but locked out. good luck with it and keep us posted with the progress and any problems you run into, or questions you have
Just Dave
06-18-2008, 09:37 AM
What is an EDC?
Boats N' Hoes
06-18-2008, 10:06 PM
engine driven compressor
killerMikeD
06-18-2008, 10:35 PM
its either a York or sanden A/c compressor converted to pump air like an air compressor, alot of off road guys run these as well as mini truckers, instead of using electric compressors, the belt from the engine drives the compressor! - mike
DaMF'inBoss
06-18-2008, 10:58 PM
Out of the two brands you mentioned, which is the best, and why?
killerMikeD
06-19-2008, 08:29 PM
I prefer the York 209 mini or 210, because they are more common, easier to work on with parts aviability, and they have a oil sump, and essentially work like a regular shop air compressor, where as a sanden 508 does not, you have to run it like a Normal A/c compressor and use the PAG oil in it, although i believe it can pump to a higher pressure.
WonUpRacing
06-19-2008, 09:21 PM
Clean ass truck man. I like going fast but have been tossing the idea around of getting a truck....decisions decisions
blackonefifty
06-19-2008, 09:26 PM
Subscribed. I have an F150 that I wouldn't mind bagging .. maybe I'll learn a thing or two from this thread.
