View Full Version : Removal of oil pan on 98 Camaro V6?
VW AUDI MAN
06-04-2008, 10:35 PM
What am i going to have to do to remove the oil pan on a 1998 Camaro V6 so i can get to the oil pump? When the car is at idel the oil light comes on but if you give it a little gas and raise the rpm's the light shuts off.
thanks you for any info possible, Adam
HeavyChevy3800
06-05-2008, 03:00 PM
The oil pump drive is part of the timing cover. You don't have to remove the oil pan.
VW AUDI MAN
06-06-2008, 10:39 AM
Is it easy to get to? Does the timing chain also have to be removed? I havn't looked at the car yet so i don't know what is all in front of it! thanks, adam
HeavyChevy3800
06-06-2008, 01:36 PM
You just have to remove the timing cover. The oil pump is in the timing cover. Five Torx bits hold the oil pump cover on.
VW AUDI MAN
06-08-2008, 11:19 AM
Thank you so much for the info. I thought it was going to be a bigger headache then i thought!
Is it a common problem with Chevy's and the oil pump going bad in this motor?
HeavyChevy3800
06-08-2008, 11:38 AM
Is it a common problem with Chevy's and the oil pump going bad in this motor?The oil pump drive is basically a set of gears driven by the crank in the timing cover. They don't fail often.
Theskaterboyanto
06-09-2008, 10:44 AM
nothing to do with the oil pan or pump if its the 3800 II motor you have a spun cam bearing the same thing happend to mine two times its a defect in the motor....... i just got a ls3 and put that into mine and a new trany and rear end and its beautiful LOL
VW AUDI MAN
06-09-2008, 04:49 PM
Is that the motor that is in this car? or were do i need to look to find out. I don't know anything about these motors, I only know adout VW/Audi motors like non other lol!
Content Relevant URLs by
vBSEO 3.2.0 RC5
