View Full Version : turbo mr2 problems
champ15
05-25-2008, 10:14 PM
91 mr2 turbo runs smooth puffs whitish blue smoke has 120psi in each cylinder all cylinders firing has new turbo no its not leaking oil, what do u guys think?
MR2driver
05-27-2008, 10:18 PM
120psi is low. Blue smoke is either the rings or the turbo. Put a spoonful of oil into the cylinders and see if the pressure goes up to 160psi where it is supposed to be.
champ15
05-28-2008, 04:56 PM
ok thanks..
champ15
05-28-2008, 04:57 PM
tried it pressure did raise do believe its rings im getting lil bit of oil spitting out of my dipstick tube..
christo4_99
05-29-2008, 06:17 PM
is it overfilled?if not you have a lot of blow-by.time for a rebuild or replacement.if i decide to replace mine i could sell it to ya...btw...how many miles on your engine? was it mantained regularly?
SangH
05-29-2008, 07:58 PM
A leakdown test is a better indication of what shape your rings are in than using oil.
tissimo
05-31-2008, 03:06 AM
itll always raise with pouring oil in.. the question is how much (and how much oil you put it too)
yea a leakdown test will give a better answer as to the engine health
flyspyder55
06-10-2008, 02:26 AM
120 is REALLY low. it should be 165-180
christo4_99
06-30-2008, 07:47 PM
always gotta comment and say something is better or whatnot...either way wore out is wore out...if it's burning oil and has low compression,uh,that might be a sign,ya think?
Content Relevant URLs by
vBSEO 3.2.0 RC5
