Suicidal Racing
05-23-2008, 02:58 PM
i got a 350 short block that blew a head gasket an sat..right now i aint had time to fuck with it.but i got all the rods and pistons out of it but 1..the one had the water in it an sat..crank is still in it with 1 rod an piston..rebuild it and go 30 over.may be less..stuck piston is only 1/4" down in the hole.has no cam..but comes with remote oil filter,oil pan,oil pump,timing cover,timing chain.
its a 2 bolt 1 rear main seal block..get some new pistons,bearings,rings and arp rod bolts and make some power...
150$ for how it sits right now..was a 300hp crate engine
