View Full Version : custom blower box for s-10?? to lay 20s...
Boats N' Hoes
05-17-2008, 11:21 AM
does any one have or know someone that has made one that doesnt suck? ive read you loose so much air volume the blower just doesnt push enough air to really keep things cool? also does anyome have pics? i was thinking of just flipping the demensions of the box so its shorter but tall to try and keep the volume higher so the a/c blows somewhat as hard?
please any help would be appreciate.
kris
DimeonDubs
05-17-2008, 11:26 AM
how much did you cut out of the box?,ive been in some that cool like stock,but i been in ones that suck
Boats N' Hoes
05-17-2008, 07:49 PM
i havent cut anything. im trying to research specs of the box for demensions that work the best.
anyone have any info??
s10forums.com <~you can find more info there...
DimeonDubs
05-18-2008, 10:17 AM
the way im doing mine is cut the firewall out for the 20's lay it out and cut the box out just big enough to be able to drive layed out..hard to explain...just gotta do it
Boats N' Hoes
05-18-2008, 12:25 PM
i searched s10forums, thats the first place i went. found a couple of pics but nothing to indepth.
dime, i get what youre saying but when you do that you lose air volume that results in weaker blowing of the air? im trying hard to find someone that has already done this lol.
thanks for the info!
killerMikeD
05-19-2008, 11:25 PM
is the truck body dropped or going to be? We can build one for you This is of one with a truck that lays on 18s with a decent size tire, 225/45/18 that we did, what size tire are you running?
This one was not too extensive, just chopped the bottom off and fiberglassed it in, depending on your tire size we may have to build a new one out of sheetmetal, but granted you will loose some power of the blower, depending on How off set the new box is from the hole in the firewall.
http://i58.photobucket.com/albums/g268/TheFabLab/Pats%20tub%20shave%20interior%20system/210.jpg
mexicant
05-20-2008, 09:49 AM
you are always gonna lose airflow -the way its done above is the only way ive seen it done
DANGERANGER
05-20-2008, 04:35 PM
The problem is when you start cutting the stock air box as much as needed for 20s you remove some of the inner circle that surrounds the blower cage. I,ve done them in steel and glass, never the same. the only why I know it works great is delete the stock system altogether and run a aftermarket kit like Classic Auto Air. Im actually fixing to do a fullsize C/K this way. You keep your stock condensor, and compressor out front, just adapt them to the evap case. Other cool advantage is a smooth firewall and a billet bulkhead that lines go thru.
Thats my .02
Boats N' Hoes
05-20-2008, 09:11 PM
ive read about the classic auto air conversion. on s10 forum that guy that fif it spent around 900...thats outta my budget. how much are you talking to the the interior firwall set up?
p.s. tires size is 245/35/20
killerMikeD
05-21-2008, 09:46 PM
a sheetmetal blower box usually runs about 300 bucks for labor, but if i were doing it i would need the truck, with the wheels. Also is the firewall tubbed? control arms? and everything else would need to be clearenced, cause once it clears the blower box its gonna hit the firewall, and or bind in the control arms. - mike
Boats N' Hoes
05-21-2008, 10:42 PM
well im low on funds....but im getting the barely legal flat arms. i already have bell tech 2in spindles. with the sd bags kit and the tubbed fire wall it will easily lay 20s. my uncles build hot rods and will help me tub the fire wall. but the a/c thing they just dont have the time to help me solve. if someone has specs or drawings i can use they can whip it up in now time....
i just want to say thanks for all the help!
kris
killerMikeD
05-21-2008, 11:55 PM
No specs, or drawings, every truck is different, BUT this should help. Let me know if u need my help.
http://i58.photobucket.com/albums/g268/TheFabLab/customblowerbox1.jpg
http://i58.photobucket.com/albums/g268/TheFabLab/customblowerbox2.jpg
http://i58.photobucket.com/albums/g268/TheFabLab/customblowerbox3.jpg
http://i58.photobucket.com/albums/g268/TheFabLab/customblowerbox4.jpg
NO_ROTAS
06-04-2008, 09:22 PM
the picture of the red truck what is the tire wheel size set up on it? thanks for the help!
killerMikeD
06-04-2008, 10:45 PM
i believe they are a 45 series, with 20in wheels, those are not pics of my blower box, just some i saved off the internet.
NO_ROTAS
06-05-2008, 01:47 PM
ok, im runnin a 35 series so they should be shorter (not much) but any little bit helps ya know. again thanks for your help.
Content Relevant URLs by
vBSEO 3.2.0 RC5
