PDA
View Full Version : Oddity on block (pics)
GTIXpress
06-25-2001, 05:19 PM
OK I have two 440 blocks rusting away outside and I noticed this on one of them. Does anyone know what exactly it does? Im assuming its to get better oiling but Im not sure. Only one block has it and it was rumored to be a racing motor. Im thinking of rebuilding one of the blocks but I always seem to have too many projects going on.
Sorry for the larger pics.
http://www.ij.net/type3lvr/lifter_tube.jpg
http://www.ij.net/type3lvr/lifter_tube2.jpg
GTIXpress
06-25-2001, 05:47 PM
If you cant tell its located in the lifter galley.
Clint
06-25-2001, 10:47 PM
Looks almost like an oil pre-pressureizer or something like that... but hell if I know...
Bob? :D
rb70383
06-26-2001, 07:25 PM
Wow. I have never seen anything like that b4. Hmmmm. I doubt it is a factory install mainly by the looks of the wear mark on top of the hose wearing it was rubbing against the intake. I cant make out where the hose comes from. Is it the oil pump? If so it really doesnt make sense to plumb in a hose between #1 and 3 lifter bores. If it was a supply it would be better to run it to the back of the block at the plug of the oil gallery. I think it might be a previous owner mod. Do you know any thing about the history of this block. Does the other block look like something could be mounted in that location also? LMK. In mean time Ill see what I can dig up.
Bob
rb70383
06-27-2001, 05:11 AM
It is what I thought Here is what I found out from the other board I go to.
Originally posted by "Someone"
jimm II
Member
Oil Line
Some one is definetly rerouting oil from passenger gallery to some where; We used a simalar set up on small blocks to supply oil to the heads but our use was for race only we installed #2 and #4 cam bearings backwards; to shut oil off from cam to heads and rerouted the lines off the front of the passenger gallery.
hope this helps in some way.
Hope that helps you out some.
Good Luck!! :)
GTIXpress
06-27-2001, 07:01 AM
Cool thanks for the info. Its probably used for something similar to that. The other block has no provisions for this tube anywhere so it was something that was put in by a previous owner. The only thing I know is the the block was used for racing purposes (or at least built that way) and its supposed to have some special pistons in it. Although I have yet to verify that.
Ive been debating on rebuilding this motor and then finding a car to put it in. Id love to find a nice Challenger or Cuda. :D But right now I just have too many cars to work on.
rb70383
06-27-2001, 07:20 AM
i forgot to include the link where i got that from
www.moparchat.com
I know what u mean by too many crs to fix i got a ton of em wanna buy one? lol
Good Luck! If u need any help just ask me.
