View Full Version : LHT V8 Turbo manifolds
MrLHT
05-14-2008, 08:06 AM
We had the opportunity to build tubular manifold for a Form lightening with merge collectors and merge into one hugh single turbo the customer supplied.
The Motor is a 5.4L built SOHC with 1000 whp in mind, The turbo is a Precsion GT4788 with a T6 in and 5" out to the down pipe.
The turbo was so large finding a place to fit it in the engine bay and still have room for a downpipe and charge pipes took the help of the engine lift.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01649.jpg
This give you an idea of turbo size with my Sony K800 sitting in the inlet.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01677.jpg
Both headers, one fully welded the other tacked.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01641.jpg
Anyone that has built header before knows the time involved, the lower of the two is the drivers side which has the steering colum pass throw it,
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01668.jpg
MrLHT
05-14-2008, 08:10 AM
This the the merge, the 2 pipes meet and a TIAL 60mm waste gate ( Supplied by customer) hopefuuly controls boost.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01652.jpg
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01655.jpg
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01666.jpg
All the welding was back purged with a route weld then filler weld for strength, For the this you need a second bottle with regulator to force the air from the insed of the pipe.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01657.jpg
Inside of the pipe
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01659.jpg
MrLHT
05-14-2008, 08:15 AM
Here's some shots of the custom intercooler we built, We used a Precision core capable of 1200 HP and built our own end tanks.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01593.jpg
Welded end tanks.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01597.jpg
No leaks here..
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01598.jpg
Liquid
05-14-2008, 08:20 AM
dats jus crazy!
sleepinsol
05-14-2008, 11:40 PM
thats gonna be one bad pickup!!!
jlude90
05-15-2008, 06:21 PM
you guys do such fantastic work, i can't wait to see this thing done
Liquid
05-15-2008, 06:25 PM
another great one off
MrLHT
05-15-2008, 09:36 PM
Somehow I can't see there been a great demand for this kind of set up, Maybe we should spend hours building fixtures just in case.
F&H Performance
05-15-2008, 10:34 PM
Thats the best welding I've seen in well i think ever.
MiDiablo
05-15-2008, 10:49 PM
You should post a link to this in the Ford Tech Forum :dunno:
I bet you'd get some info from the Ford Lightning Owners in there... Also, look into posting over at some of the L Forums, like "NLOC" for instance.
Fab work looks insanely awesome!
-Jo$h
Alpha
05-15-2008, 11:18 PM
Great work John! What is new though :lol: That turbo will make 1000whp. We made 1034whp through an auto with more left in it. It's hard to tell from the pictures but I assume there wasnt enough room to prioritize the wastegate more? I'm sure it wont be an issue with the boost he will be running though
MrLHT
05-17-2008, 07:49 PM
Thanks guys. Alpha, There wasn't much room for the turbo let alone anytning. I think it will be fine as he will be running high boost most of the time.
smokeshow
05-19-2008, 06:45 PM
The intercooler welds look good!
On the tube/pipe, are you doing open root? Or bevel/feathered edge?
309?
freakyfast95GTS
05-21-2008, 03:24 PM
Welded end tanks.
No leaks here..
such nice welds around the seams but whats with the top pic welds where the tanks meet the core? did you grind the blobs down? or is it just a pic-figment?
civicSi07
05-21-2008, 06:17 PM
^ thats where he tack welded it to hold the tanks in place
MrLHT
05-21-2008, 06:37 PM
The "Blobs" are tacks to hold it in place. Aluminum pulls and mishapes as it's welded or heated. Once we come up a tack, we grind it off than continue the weld.
Content Relevant URLs by
vBSEO 3.2.0 RC5
