Ls_[eg]hatch
05-11-2008, 02:52 PM
I am selling my kicker system cuz i need some cash
i have 2 12'' kicker CVX dual 4ohm in a ported box built by big mike at custom edge audio. with a sx1250.1 amp. the subs together total 1500rms with a total max at 3000watts. the subs retailed for 349.99 each and amp was 1119.99. i only paid 650 for it tho.
looking for 700 obo. pics up soon
specs
cvx 12"s
MAX Power Handling: 1500 Watt each
RMS Power Handling: 750 Watt each
Frequency Response: 20-500Hz
DUAL 2-Ohm Voice Coil
Cut Out Diameter: 11 1/8 28.3
Sealed Box Volume: 1 - 4.60 cubic feet
Vented Box 1.75 - 2.25 cubic feet
Mounting Depth: 6 5/8"
Kicker SX1250.1
Features* Built-In 32-Bit Digital Signal Processor (DSP) - UltraMatch Gain Structure; single-band parametric KickEQ (variable frequency, boost/cut and Q); high-, low-, or band-pass crossovers (variable frequency, 6-36dB/octave slope)
* Isolated dual power supplies
* Fan cooling
* Remote gain control (Full Range)
* Custom-tooled oversized power and speaker output terminals
* PreAmp Signal Transfer (PAST) output RCA lack
* Soft muting circuit controlled by the DSP
* Soft start turn-on circuit for deduced startup load
* Removable cast aluminum EndKaps
* In / Out strapping ports
* 1-ohm load optimized
Specifications* Amplifier Type: Mono
* RMS Power: 625W x 1 @ 2 ohms
* RMS Power: 1250W x 1 @ 1 ohms
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-200 Hz
* Signal to Noise Ratio: >100 dB
Dimensions with EndKaps (Inches)Length: 22.5"
Width: 10"
Height: 2.5"
specs
cvx 12"s
Kicker SX1250.1
* Fan cooling
Width: 10"
Height: 2.5"
