PDA
View Full Version : 3sgte cam specs
Alltracfreak
05-11-2008, 02:35 PM
can somebody tell me all gen 3sgte cam specs including caldina? and what can a stock 3sgte valve train handle??
dohcvteccivic
05-18-2008, 09:12 AM
SangH
05-20-2008, 01:22 AM
Gen2 cams ~235* Duration ~8.5mm max lift on both sides.
Gen3 cams. Intake cam has slightly longer duration, ~4-5*. Has slightly higher lift, ~.5mm. Also ~1.5-2* advanced. Exhaust cam is identical to gen2, except is 4.5* retarded (in relation to gen2 exh. cam position).
I don't know the specs on the gen4, but it doesn't matter since they aren't interchangeable. The caldina uses COP ignition, lacking a distributor (ergo, no notch on the cam) and uses an internal cam sensor.
-Sang
christo4_99
05-29-2008, 06:29 PM
i have some 250s made by cat cams in begium...billet...
Inlet
Clearance 0.2mm
Valve Lift 8.80mm
Duration @0.1mm 250deg
Duration @1.0mm 232deg
Lift@TDC Without clearance 1.4mm
Exhaust 0.2mm
Clearance 8.80mm
Valve Lift 8.80mm
Lift@TDC Without clearance 1.40mm....kinda strange to me but the duration @ 1mm is the same as hks 272s
Alltracfreak
05-31-2008, 01:44 AM
i was just wondering wut i could use on a stock head i have supertech dual valve springs and titanium retainers im trying to get rid of need the money bad
