View Full Version : The big shop project
ChrisN1313
05-09-2008, 03:07 PM
2001 mustang street car being turned into a 6.50 car. It should go faster than 6.50s but thats the class we are building it for.
Engine
Teskid Block
Eagle H Beam Rods
Manley Dished Pistons coated
Valve Reliefs in pistons
ARP Main Studs
Stage 8 side bolts
Arp Head Studs
Eagle Crank
Comp 278 cams
Comp Valve Springs
Comp Retainers
+2 Oversize SS Valves
Worked 2v heads
Clevite 77 main bearings
Edelbrock 2v Carb intake
meziere electric water pump
mmr billet gear oil pump
dss main girdle
fidanza adj cam gears
Unknown Carb
Unknown Radiator and fan
Unkown Oil Pan
Trans
J.W. 4.6 to Glide bellhousing
Unknown TQ Converter
Powerglide
PST Custom Carbon Fiber Driveshaft
Unknown Trans Cooler
Fuel System
Aeromotive a-4 regulator
MagnaFuel Pump and filter
Sumped factory tank
Rear End
Factory 8.8 Braced and with 9" ends
Moser 35 Spline Axles C clips
Moser Spool
TA Rear end cover
frpp 4.10 gear to start with
Suspension
Front Coil Overs with qa1s
PA Racing Chromoly k-member
PA Racing Chromoly a-arms
Steeda Bump Steer Kit
Maxium Motorsports 4 bolt caster/camber plates
Drag Launch springs in the back
Custom Anti Roll bar
Pinto Style Manual Rack
Custom Double adj uppers and lowers
Brakes
Aerospace Single Piston Brakes
Aerospace master cylinder
Electronics
MSD Mod 6 with harness
Inovative Wideband
Autometer Phantom Tach
Autometer Phantom Water
Autometer Phantom Oil
Autometer Phantom Nitrous
Factory Coils
Chassis
10point Chromoly Cage
6" Cowl Hood
Motor Mid Plate
Solid Motor Mounts
Wheels and tires
Weld 15x3 and 15x10 draglites
Unknown M/T Radial Whatever we can squeeze in there
Power adder
Wilson 2 bar plate kit
I know I'm missing some stuff there is so much shit that we have bought that sometimes we just forget what we have.. Heres some pics as well and we will continue to add to during the process.
Pictures Found here
http://pceuphoria.net/gallery2
Click 01 mustang 6.50 car
ChrisN1313
05-13-2008, 12:01 AM
43 views and no comments? scared of whats coming ? comments on the build?
sittinlow88
05-13-2008, 12:06 AM
Ummm... kinda need more pictures to make it a little more web friendly! but it sounds good
KAILUAZ
05-13-2008, 12:10 AM
The only pic I see is the hood. Car sounds like it will kick ass though!
ChrisN1313
05-13-2008, 12:23 AM
The only pic I see is the hood. Car sounds like it will kick ass though!Hmm i must of linked it wrong. One Min.
hmm sound like your spending alot of money to get beat by me , btw when are u coming for those timimg stuff?
Scott
05-13-2008, 07:34 AM
Pics of biz-an !
ChrisN1313
05-13-2008, 08:21 AM
call me later today I lost your damn number again:lol:
sittinlow88
05-13-2008, 06:37 PM
Ahh, much better pics!!!
ChrisN1313
05-18-2008, 07:37 PM
Just waiting on the last of the parts now. Fuel pump y block and filters should be here tuesday. I bought this http://www.magnafuel.com/products/efi/pumps/MP-4301-540pxW.jpg
4303 prostar pump good for 2000hp na about 1500 forced. Should be a good pump for a while.
Got my new radiator in its a becool alum. radiator
Also got my msd mod 6 box and wiring harness in. Woot
http://images.hotrod.com/techarticles/engine/hrdp_0804_07_s+ford_4_6_engine+msd_ignition.jpg
MY JW bellhousing 4.6 to powerglide shipped friday so that should be here Monday or Tuesday as well as my flexplate.
ruler
05-18-2008, 10:45 PM
what comp cam # were those cams
ChrisN1313
05-19-2008, 12:04 AM
just 278s
ChrisN1313
05-19-2008, 01:55 PM
dropped the aluminum block and other parts to Chris Nelson today for the machine work. Now its time to call fox lake :)
1slow1g
06-19-2008, 04:48 PM
my opinion is that you will never put half as much nitrous threw a 2v as you think you will. and that you will chase 6.50s untill the day you buy a turbo kit.
then you might go 6.50s a few times before you start lifting heads and pushing out gaskets at witch point you will throw a pushrod motor in it and be happy.
but what do i know about mod motors right?
ChrisN1313
06-19-2008, 06:09 PM
your opinion doesn't really matter espically coming from someone that doesn't have a car last time I checked or anything decent. I have a few tricks up my sleeve and if you find it hard to beleive that it wont go 6.50s I want some of what your smoking. I need to pickup a 1/2 sec from what I, which was a few bolt ons and 175 shot. So nice try there pal. What do you have? Wheres that old 9.50 turbo car you had
MiDiablo
06-19-2008, 06:33 PM
:corn:
864I'DCaprI
06-19-2008, 06:42 PM
uhh oh, drama on TR?? who would have thunk...
Someone pass the popcorn....
G/L with the project.....
91Notch
06-19-2008, 08:01 PM
But remember it only went low 7's when I was the pilot, it went high 7's with you in the driver seat :lol:
:corn:
1slow1g
06-20-2008, 01:33 PM
well my budget is small so i havent put my own car back together however james albert and i put something together witch i would be more then happy to bring out.
i would love to c a vid of your car goin 7.0 you barly held walters fwd dsm out from a dig on an 8th mile street. if you do make it to 6.50s youl do it with a super light chasis and a shot half the size of the one u been dreamin about, even the other nitrous 2v guys think your a jackass.
p.s. how many pics of blk cocks did you look at before you found one you liked. makes me laugh every time i think about it.
91Notch
06-20-2008, 01:37 PM
For the record it never went 7.0. Best was a 7.30. So he needs .80 to go 6.50. I am not seeing that being too much of a problem :dunno:
. Especially with the money he has been spending. Ther is no reason why it won't atleast go into the 6's.
1slow1g
06-20-2008, 02:02 PM
i agree it should be able to go into the 6s for sure but its not gonna do it by shoving tons of bottle threw it.
it will prolly take a 300 shot with good heads and a large cam. if you can make 600 wheel you should be able to get it into the mid 6 range with some weight reduction. my concern would be making it last the mod motors arent too nitrous friendly after about a 200 shot.
just sayin for a race car mod motors are not the way to go, all that money hes spending and you could prolly stick a bottle on the coupe and go 6s for alot less.
Adrenalin
06-20-2008, 08:14 PM
This thread needs more pics posted in it, this reading stuff is overrated. It sounds like it's coming along nicely tho! ;)
MiDiablo
06-21-2008, 12:51 AM
/\ + 1 for pics... And I mean PICS - no clicky linky thingys :evil:
ChrisN1313
06-21-2008, 04:47 PM
Just imagine a striped gt on jack stands with some spiderwebs
and a mountain of new parts in my garage and a motor sitting at a machine shop
91Notch
06-21-2008, 04:50 PM
^^^ ya that pretty much sums it up.
MiDiablo
06-21-2008, 05:06 PM
:nono:
ChrisN1313
06-21-2008, 05:17 PM
:nono:
but its the fastest car on jack stands .
MiDiablo
06-21-2008, 07:29 PM
Mine's the fastest in my driveway when my father and I push it around :crack: :lol:
shinysideup
06-22-2008, 12:02 AM
I wanna see this filthy gee-tee,forget the summit catalog pics!
DOHC LINC
08-11-2008, 06:08 PM
wanna go phast? i have a set of DOHC "C" heads in my garage if a want to buy em. the number one chamber is a little beat up from a peice of alum that got in there some how and is now stuck between the exhaust valve and the seat. the motor ran pretty good in my lincoln untill this happened.
ChrisN1313
08-11-2008, 07:42 PM
you mean to tell me I cant go fast with 2v heads. Thanks for the kind words. But I have plently of mod motor parts and heads in my garage including 4v heads.
That was a pretty fucked up thing to say.
GNs-r-slow
08-11-2008, 08:40 PM
Maybe fast with 2v but not phast bro, come on now!! :D
D-Phresh
08-11-2008, 10:32 PM
:lol: projects looking good bro:D
GNs-r-slow
08-12-2008, 03:44 AM
:lol: ALL my projects are going backwards!!!
paintballa213
08-25-2008, 10:17 PM
more pictures!!!
ChrisN1313
08-25-2008, 11:33 PM
more pictures!!!
more coming tomorrow or wed.
Content Relevant URLs by
vBSEO 3.2.0 RC5
