PDA
View Full Version : Got a CEL...
Wrxgurl06
05-06-2008, 07:15 PM
Today on my way to work, I had just turned onto the street I work and my car threw a CEL. It's P0420 "Catalyst system efficiency below threshold". I just got tuned on Saturday and everything has been great. I currently have APS CAI, APS TBE (no cat) and Cobb AP.
Any ideas?
djerickd
05-06-2008, 07:21 PM
disconnect battery... wait... reconnect battery...
now go figure out a way to trick the ECU via resistor or turn off the code in the ROM so it doesn't come back.
cheesetits
05-06-2008, 07:40 PM
I got the same code bro, and I got tuned on Friday. Maybe gadiel forgot to take it out of the ROM
13Brotary
05-06-2008, 07:44 PM
That's for the dp 02 sensor. You can do either a mechanical fix or electrical. The mechanical involves using two spark plug extensions and screwing them into the exhaust pipe and the 02 sensor into the end of the extensions. The electrical fix uses a resistor in the 02 sensor cable. Both are really easy and cheap, or you could just tune it out.
Wrxgurl06
05-06-2008, 07:46 PM
Shouldn't it have been tuned out by Gadiel? It never did it when I was stage 2.
13Brotary
05-06-2008, 07:52 PM
Yeah that is strange that it didn't come up before. What kind of stage 2 tune was it? You're running a catless TBE right? Is the rear 02 sensor stock?
Wrxgurl06
05-06-2008, 08:12 PM
It was Cobb AP stage 2. Yeah, it's catless and the rear 02 has never been touched.
-faded-
05-06-2008, 08:16 PM
just have him shut that light off if you can get ahold of him so it doenst keep coming up. mine did that after a tune once. just had the light turned off, its nothing really.
cheesetits
05-06-2008, 08:19 PM
If you get in touch with him, let me know. I need the same problem fixed
Wrxgurl06
05-06-2008, 08:31 PM
Turn off the check engine light?
Ok. I'm going to PM Joe.
flystiguy01
05-06-2008, 08:52 PM
theres basically a checklist of things that your car checks for while it is running.. any tuner has the capability to uncheck the one that is showing up.
Wrxgurl06
05-06-2008, 08:53 PM
Ok, I gotcha. :)
WTFchuck
05-06-2008, 09:07 PM
that might throw off there afr's since they were tuned that way
13Brotary
05-06-2008, 10:04 PM
The AP gets rid of the CEL (tunes it out) so that's probably why it didn't show up. If you have a Tactrix and laptop you can get rid of it yourself.
Wrxgurl06
05-06-2008, 10:13 PM
That's what I figured. But I don't have the cable to do it myself.
cheesetits
05-06-2008, 10:35 PM
Cant you use the AP cable to do it yourself? Ive been using it to datalog for a couple of years. Or is it just able to datalog and not tune with?
Wrxgurl06
05-06-2008, 11:55 PM
I'm not sure, plus even if I could I don't know what to look for...lol
LDadrenaline
05-07-2008, 02:33 AM
yes you can check and clear codes with the accessport
i cant believe gadiel would forget something like telling the ecu to ignore that code. thats like tuning subarus 101. first thing is have it ignore the O2 codes.
reason you didnt get it before is that all accessport maps are programmed to ignore it.
Wrxgurl06
05-07-2008, 11:45 AM
Oh, yeah I already cleared the code with the AP. I thought the other guy meant turn of the light with the AP.
cheesetits
05-07-2008, 12:40 PM
A little off topic but what did you pull on that dyno Wrxgurl? I was able to get 275/280 with my stg 2+ sti with a conservative 17-18 psi tune and 305/319 on an agressive 20-21psi tune.
Wrxgurl06
05-07-2008, 12:55 PM
Stage 2 was 216/266 and after tune it was 244/292.
Nice! What mods do you have?
warfare
05-07-2008, 01:01 PM
You can turn this CEL off with Cobb Streetuner if running an access port. If you do not have Streetuner you need to have your Pro tuner switch it off in the map.
cheesetits
05-07-2008, 01:04 PM
Mods are Invidia TBE, Injen Cai, Ngk one step colder plugs
I'm Slow
05-07-2008, 03:45 PM
I will let gadiel know. I he can just email you a updated map with the cel turned off. PM me your email addresses
Wrxgurl06
05-07-2008, 04:32 PM
^^PMed
cheesetits
05-07-2008, 05:57 PM
/\pmed
LDadrenaline
05-08-2008, 11:17 AM
yep i was going to say just email gadiel and let him know who you are and he will send you the same map qith the CEL correction
