View Full Version : Line output in 2006 honda civic help?
20whiteboy03
05-06-2008, 09:19 AM
I{ was trying to put a line output converter in my g/f 2006 honda civic and i tapped into the stock sub but it will not send a signal from the line output to the amp wtf.
TBSpyder
05-06-2008, 02:23 PM
The signal may not be strong enough. Try tapping into a full range speaker instead.
jriggs
05-06-2008, 10:02 PM
sub might be a 'duel voice' sub or have some crazy wiring my gs did. try using one lead as a + and then ground the - and see if you get a signal. its what i did to make my line out work
nofxareforkids
05-13-2008, 03:18 PM
also check your line output converter a lot of them are manufactured like crap and some just don't work. when i worked for circuit city we had entire shipments of em be bad
A passive line output convertor (Hi/Lo Convertor with no power/ground connections) does not work really well at getting a useable signal from the sub speaker wires. You are better off tapping the right rear and left rear speaker wires to get signal to the convertor. You will get a cleaner full range signal and it is usually a little more adjustable than using sub amp output wires.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
