ThaiRacer
05-01-2008, 02:35 PM
heres the specs to my amp and i'm going to be buying "Skittles" 2 audiopipe eyecandy txx 800rms 1600 max watt
Amp:
VIBE Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 400 watts x 1 chan.
2 ohms: 800 watts x 1 chan.
1.3 ohm: 1000 watts x 1 chan.
Max power output: 1800 watts x 1 chan.
Stiffly regulated PWM MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost)
Glass Epoxy PCB with SMD Technology
Custom Terminal Block for Speaker Connection
Speaker-level
Preamp RCA outputs
Thermal, Overload, and Short Protection circuitry
Phase Control 0~180
Soft Turn On/Off
Gold-plated RCA level inputs
Variable low-pass filter (50-150 Hz, 24 dB/octave)
Subsonic Filter (15-40 Hz, 24 dB/octave)
Frequency response: 15-150 Hz
Dimensions: 10.25"L x 15.10"W x 2.36"H
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
Amp:
RMS Power Rating:
Speaker-level
Preamp RCA outputs
Phase Control 0~180
Soft Turn On/Off
