Chassis & Suspension Tech Cages, braces, suspension set up and more
hub assembly
Old Apr 28, 2008 | 11:44 AM
red1civic's Avatar
Default hub assembly
hello im new to this forum/ i need some help i need to replace the studds on my 94 honda civic ex and i was wondering what size socket do i need to remove the big center bolt/ also if i get the part off the car di i need to machine press the bearing back in or can i just take it off replace the studds and be done with it/ i will be posting alot on here cause im new to the civic world and need alot of info about things/ i have a 94 honda civic ex with a integra front clip / and ls motor / i/h/e// it needs alot of body work / i got the car for free and it runs just the studds need to be replaced/ ill try to post a pic later/
thanks red
Old Apr 28, 2008 | 06:39 PM
GSL_SE's Avatar
you axle nut is a 32mm ... the hub bearing needs to be pressed out and in .. and no problem we all were noobs at a time
