PDA
View Full Version : FS:Trilogix AM777 Car Alarm Keyless Entry (Directed Electronics product ) $40.00
hekkler28
04-28-2008, 10:09 AM
I have a brand new Trilogix AM777 Alarm Keyless entry for sale . I have detailed the specs of the alarm below . If you have any questions please PM, email ,or give me a call at 813-334-0351.
$25.00 takes it
Manufacturers website
http://www.bypasskit.com/product.aspx?prodid=AM777
Code Hopping
Multi-function 3 buttons transmitter
Code learning
Use up to 3 car transmitters per module
One transmitter can use up to 3 modules
Remote control Arm/Disarm
Remote control door lock/unlock
E-EPROM Code memory
Plug-in override switch & function
Defective zone by-pass
Remote car finder
Status memory when power off
Starter interrupt relay (optional)
Parking light relay built-in
ACC off - door unlock
Grounded output for starter disable relay
Positive/Negative door lock/unlock output
Audible and visual arming/disarming signal
Tamper memory with chirp, light & LED indicator
Multi-function LED indicator with tamper memory
Remote control panic with auto 30 sec shut off timer
Remote silent Arm/Disarm
Valet mode
Positive and negative door trigger inputs
Auxiliary Ground trigger input
Plug-in 2 stage shock sensor
Factory alarm override
Remote control channel 2+3 output
Anti-Scan
PROGRAMMABLE FEATURES
Door lock timer: 0.5/3.5sec
Automatic arming: On/Off
Door open warning: On/Off
Anti-carjacking: On/Off
Current Sensor: On/Off
http://i163.photobucket.com/albums/t320/hekkler01/100_0874.jpg
hekkler28
05-18-2008, 10:01 AM
Bump
hekkler28
07-22-2008, 06:09 PM
Bump
