PDA
View Full Version : LS1 question
asia989
04-21-2008, 08:00 AM
How much of a pain would it be to drop into a 92 silverado?
Superluminal
04-21-2008, 12:16 PM
You might get some back pain, but that's nothing some Advil can't clear up.
Country Boy
04-21-2008, 01:06 PM
Anything can be made to fit with enough work. The LS1 motor mounts are in a different position and will need a tranny X-member and all accessories and PCM, but its doable.
TURACE24
04-21-2008, 01:58 PM
+1 on the conversion mounts. Best way to go, is with a donor car, a totalled out trans-am or camaro, and swap the motor, wiring harness and whole nine yards out. Otherwise, you're asking for alot of un-needed work and nightmares.
J@meson
04-21-2008, 07:28 PM
Full-Size Chevy - Main Index (http://www.fullsizechevy.com) it happens more then u think
DANGERANGER
04-29-2008, 01:44 PM
I use the conversion mounts that adapt over and use stock GM SBC mounts and put it in right location. Use shorty headers for Camaro. If your truck was originally an O/D auto you shouldnt need a trans xmember. If you have the stock camaro/vette harness $500 will turn it into a stand alone harness, or buy a new one for a $1000 or less. Electric fans a must, better drop in fuel pump, fuel line adapters, Intake filter of some sort, etc.
J@meson
04-29-2008, 03:59 PM
in late 93 they started using the 4l60E in the silverados. early 93 and back was TH400, TH350, and 700R4 which he most likely has the 700R4
asia989
04-30-2008, 05:10 AM
i think its a th350 but im not quite sure, im trying to source a 350 5.7 for it but if i find a ls1 ill go that route
TURACE24
04-30-2008, 09:46 AM
probably not a TH350... what does the pan look like on it?
asia989
04-30-2008, 02:35 PM
short rectangle
TURACE24
04-30-2008, 02:38 PM
16 bolts? and is it 3 spd with an overdrive.
