View Full Version : Project Tampa Terror ae86/3tc turbo finally begins
3tc power
04-18-2008, 09:50 AM
This project has been going on for a few years now. It is taking long because of me not having the time i want to spend on my ride. haha being the only engineer at my job that do what i do has it's downfalls i guess :roll: anyways back to the car. Here is my ford 8.8 shortened down for my 84 ae86. now i tried to keep it as simple as i can, so what i did for the rear end to fit is i only cut the driver side of the ford rearend to the same length as the passenger side. then when we finished cutting and welding, we just went to the junk yard and got another 8.8 passenger side axle to use on the driver's side of the rearend. the rear end i used is from a ford explorer eddie bower with disc brake, 373 gears and posi.
http://i234.photobucket.com/albums/ee20/3tcpower/530621460d.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/7864b3436b.jpg
As you can see the 15x8 fits really well with the 5.5 backspace.
http://i234.photobucket.com/albums/ee20/3tcpower/205d30cd3b.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/ca29671407.jpg
i will be having some more updates really soon
3tc power
04-26-2008, 08:16 PM
sorry i took so long getting the pictures up. well here is some more pictures of the rear end set up.
http://i234.photobucket.com/albums/ee20/3tcpower/P1010001.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P1010002.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P1010003.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P1010005.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P1010006.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P1010007.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P1010009.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P1010008.jpg
3tc power
04-26-2008, 08:17 PM
So... here are some pictures of the car before the madness began :?
http://i234.photobucket.com/albums/ee20/3tcpower/P3170005.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P3170006.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P3170004.jpg
3tc power
04-26-2008, 08:18 PM
Well i started taking everything out, and man i hate it when you don't really notice how bad something is until you pay attention to it. below you will see what happens when you don't use the the plastic battery tray when the battery is leaking acid. oh well i will be sanding it down so screw it :?
http://i234.photobucket.com/albums/ee20/3tcpower/P3170007.jpg
here is another thing i really hated. look at this crossmember!!! the dillhole who i bought the rolla from welded a set of mounts to the crossmember and now i need to get a replacement one. i will also be getting rid of the busted p/s rack n pinion.
http://i234.photobucket.com/albums/ee20/3tcpower/P3170008.jpg
well, i started taking the front end off.
http://i234.photobucket.com/albums/ee20/3tcpower/P3180009.jpg
man!!! that booster was a pain in my @ss to take out. i'm getting there one step at a time.
http://i234.photobucket.com/albums/ee20/3tcpower/P3180010.jpg
OH BOY!!! look at this mess i made :lol: :shock:
http://i234.photobucket.com/albums/ee20/3tcpower/P3180011.jpg
whiteknight
04-28-2008, 03:41 PM
good luck to you sir, you seem to have one hell of a project started.
3tc power
04-29-2008, 11:14 PM
thanks man...yes its an on going project, but i will have it done before summer passes.
3tc power
04-29-2008, 11:16 PM
OK! well i'm back and now i'm working on getting the engine bay and front wheel wells stripped of its paint. looking at how these car were built, i know i'm in for a battle. first i will start with the battery tray.....man this thing is rough looking. :evil:
now we know what will happen if you let battery acid sit on metal long enough :oops: well as you can see in the picture i'm drilling out the stamped welds that holds the tray in place.
http://i234.photobucket.com/albums/ee20/3tcpower/P4220013.jpg
this Mother F...... thing is getting on my last nerves
http://i234.photobucket.com/albums/ee20/3tcpower/P4220012.jpg
Finally after 30 minutes of playing with this POS...i got it off. :banana:
http://i234.photobucket.com/albums/ee20/3tcpower/P4220014.jpg
With the tray out of my way i can start stripping the engine bay paint.
this is all i used for the paint..this stuff is top of the line shit! there is now odor at all and unllike the other spray can strippers you can just constantly keep spraying without having to run awy from fumes. i recommend this to anyone.
NOTE: please don't get this stuff on your skin..
http://i234.photobucket.com/albums/ee20/3tcpower/EAR322_2_R.jpg
and you will also need this to peel away the paint
http://i234.photobucket.com/albums/ee20/3tcpower/12921.jpg
3tc power
04-29-2008, 11:17 PM
well its time to start applying paint stripper to the engine bay. wow after 10 minutes or so after applying the stripper this is whats left.
http://i234.photobucket.com/albums/ee20/3tcpower/P4220015.jpg
the fire wall was bare metal in minutes but other parts needed heavier coats. so while a wait for the stripper to do its job, i went ahead and started cleaning the tranny. now i know you remember what it looked like.
http://i234.photobucket.com/albums/ee20/3tcpower/P4290016.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290017.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290018.jpg
there is nothing that a little rayal purle cleaner and a brush can't do :clap: it looks brand spanking new :beer:
http://i234.photobucket.com/albums/ee20/3tcpower/P4290025.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290026.jpg
omgosh
05-04-2008, 06:45 PM
That looks like its going to be awesome, good luck!
ninja999
05-04-2008, 07:43 PM
did you get a new crossmember yet rudo?
3tc power
05-05-2008, 03:20 PM
yes i got one but i still need a wire harness for my ride. i just need the front half for the sr5 that goes to the oil sensor and water temp sensor etc. if anyone has one of those harnesses please let me know.
3tc power
05-05-2008, 03:23 PM
http://i234.photobucket.com/albums/ee20/3tcpower/P4290019.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290020.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290021.jpg
i used the 80 and 120 grit sandpaper wheels for the drills for all the tough spots. i think it came out pretty good for the lack of tools i had.
http://i234.photobucket.com/albums/ee20/3tcpower/P4290022.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290023.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290024.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290027.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290028.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290031.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290030.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/P4290029.jpg
my final step is to go over the engine bay with a heavy duty cup wire wheel
itsjustaneon
05-07-2008, 03:25 AM
Glad you are doing it the right way!
Cant wait to see it done!
DAT*NIZ
05-07-2008, 10:36 AM
This is gonna be a sick project! 3tc>4age!
3tc power
05-08-2008, 12:06 AM
thanks bro! i this car is going to be my daily driver, so i want it to be done right the first time so later on i don't have to go back over it. basically what i'm doing is prepping the engine bay and wheel wells for paint "which i will do on my own" that way once the bay and wells are painted i can get the car running somewhat then send the rest of the body to be painted by a pro. i
DAT*NIZ
you are right about that, 3tc>4ag all day. don't get me wrong, the 4ag is a very good motor but pound for pound the 3tc will out perform the 4ag n/a or turbo. hehe but i still rep the 4ag because my cousin in St. Croix U.S. Virgin Islands has one and its bad as hell.
http://i234.photobucket.com/albums/ee20/3tcpower/3heads.jpghttp://i234.photobucket.com/albums/ee20/3tcpower/lickass.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/2heads.jpghttp://i234.photobucket.com/albums/ee20/3tcpower/3s.jpg
http://i234.photobucket.com/albums/ee20/3tcpower/2m.jpghttp://i234.photobucket.com/albums/ee20/3tcpower/3m.jpg
JAYSKILLS
05-08-2008, 01:21 AM
NICE bro!!!
atleast you know what you want
can't wait to see how this turn out!
3tc power
05-08-2008, 11:36 AM
thanks man!
Content Relevant URLs by
vBSEO 3.2.0 RC5
