View Full Version : 1993 transam not starting
speeddensity
04-16-2008, 02:48 PM
i recently installed a rebuilt lt1 into my 93 ta .its all back together ready to start im getting power to all of my accesories when i turn the key but no power to the stater at all , ive even tryed bumping the starter it turns over tha way but still not with the key, so my last effort was unplugging the brain that somewhat worked im now getting power to the starter its somewhat turning over but not at full force im now getting a clicking noise while the starter is turning almost like the noise when your battery is dead but this battery is new.im at a loss can some give me some insight??????:-o
myltwon
04-16-2008, 04:22 PM
bad pcm/ecu maybe?
wmskateteam
04-16-2008, 04:51 PM
just because the battery is new does not mean it's fully charged if you're getting power and it's not intermittent then charge the battery you should be set
Mark_in_FL
04-16-2008, 06:05 PM
Bad ground????
Have you checked the voltage at the battery, starter, ect?
streetburner
04-16-2008, 11:57 PM
could also be the starter gone bad and aint outting out the voltage it needs ?? but also check all the grounds like mak in fl said
Tiffiny
04-18-2008, 03:59 AM
vats???? sounds like to me
TURACE24
04-21-2008, 01:53 PM
hook everything back up.. pcm and such. did you try spinning the motor by hand first, to see how tight it was? pull a few spark plugs out, and see if the engine isn't hydro-locked with assembly oil. (it's happened to me) try cranking it with half the plugs out and see if its any easier.
Sanbuda
04-22-2008, 09:22 PM
you need to check the grauns on the car
Sanbuda
04-22-2008, 09:27 PM
this type of motor work wiht graun signals
TURACE24
04-22-2008, 11:04 PM
1994formulalt1
04-23-2008, 08:46 AM
bad ground? could be something simple
BrokeMofugga
04-23-2008, 09:50 PM
Im going to say bad grounds.or somethings not hooked up
Content Relevant URLs by
vBSEO 3.2.0 RC5
