View Full Version : Help !!! my constant power isnt there ...
GSL_SE
04-15-2008, 03:54 PM
i own a 96 integra and my constant power isnt working so my radio resets it self evrytime i cut off the ignition .. and so does my clock = ( i need this fixed can someone help me out .. thanks
Notladstyle
04-15-2008, 04:41 PM
The easiest and quickest solution is to route a new wire from the ignition harness to the radio harness.
or pay me $30 and ill do it :p
TBSpyder
04-15-2008, 08:59 PM
...........if you know the wire in the ignition harness to tap. If not, the easiest way would be to go directly to the battery..and use an inline fuse.
GSL_SE
04-15-2008, 11:31 PM
thanks all .. on my fuse box there are unused tabs that had 12v power to then i used a female fitting and plugged a wire into it and tapped it into the factory harness for the radio .. all seems to be working fine .. thanks
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
