manifoldmike
04-09-2008, 08:52 PM
so the 700 hp integra build turned into the 1000hp integra build a couple weeks after we finished the car thanks to ryan.
we had some set back with the engine, so were going to take care of that and get the build going. we had to already switch out the rods (5/16 bolt eagles) for some beefyer ones, so its not that big of a deal.
the engine is out of the car (thanks jon) and waiting for our in house builder to get his hands on it (antonio).
things we going to be throwing on there:
beefy rods (can get eagles with 3/8 bolts, but might get somthing else)
borg warner s372 race cover .100 a/r back side
second stage of 1600 cc injectors
second fuel system (regulator, pump, lines, fuel cell)
twin disk clutch
beefy axles
new paint
maybes:
front face bottom mount manifold
re-routed 4" downpipe
1000hp air to water intercooler setup with honda half core heat transfer.
cage
this is going to be some fun stuff so keep your eyes peeled.
i'll post up some pics of the turbo, car and engine in the next couple days.
*if anyone is looking for a direct bolt on kit that has proven power numbers (480whp@12psi, 630whp@18psi) with about 1000miles on it we are selling his old kit for $4000 obo. this includes: 4to1 top mount manifold, t67 turbo (.70 a/r compressor, .96 a/r hot side, p-trim turbine, water cooled, 4" welded v-band), 4" downpipe with 4" e-cutout (3" v-band to rest of exhaust), turbosmart 48mm wastegate (with all springs), 2" dump tube that dump under engine, 2.5" hot side and 3" cold side polished intercooler pinping, precsion intercooler 24x12x3 high density cast end tanks, turbosmart raceport bov, stainless -3an feed line and -10an drain line, black couplers, t-bolt clamps and 4" polished cold air intake with aem dry filter.
** does not allow power steering or a/c
current setup:
http://www.alphatuning.com/images/welding/acura/integra/dartturbo87.jpg
http://www.alphatuning.com/images/welding/acura/integra/dartturbo88.jpg
http://www.alphatuning.com/images/welding/acura/integra/dartturbo90.jpg
http://www.alphatuning.com/images/welding/acura/integra/dartturbo93.jpg
twin disk clutch
beefy axles
new paint
maybes:
cage
current setup:
