View Full Version : went to bradenton tonight! 50 trim SRT-4
concordcobra
04-04-2008, 12:00 AM
Well we went out tonight, and i got some runs in! I was in the white SRT with the black rims...
On pump gas, with the 50 trim set up....and STREET TIRES!!!!
12.6@119.8 MPH!!!! rediculous...
chevySS
04-04-2008, 02:03 PM
i saw u out there, car is quick.....i was on my bike....got some ok passes myself... 10.6 @ 129 on a bolt on 600 with crappy 60' lol....goin back tonight, goin for mid/low 10's, bike has more in it...
concordcobra
04-04-2008, 02:26 PM
Nice i actually watched one of your runs... bike sounds good! we may go out tonight, not sure yet tho
chevySS
04-05-2008, 01:17 AM
went back tonight and ran a 10.540 @ 131.8......hoped for beter but that will do for a R6....time for spray....
concordcobra
04-05-2008, 12:02 PM
130 traps for an R6 is really good man...
That is a shit load of mph for a mid 12!
chevySS
04-11-2008, 04:51 PM
best trap was a 132 but the bike has more in it....went 10.5 at 130with a 1.7 60' :mad: track prep wasnt to good, just spining off the line ......bike has 10.20's 10.30's in it with a mid 130 trap speed....and its still all motor lol....putting a direct port kit together as we speak....goin for mid/low 9's.....heres the slip and video so people dont say im lieing...
http://i63.photobucket.com/albums/h156/xtremegsxr/100_1490.jpg
http://i63.photobucket.com/albums/h156/xtremegsxr/th_021.jpg (http://s63.photobucket.com/albums/h156/xtremegsxr/?action=view¤t=021.flv)
chevySS
04-12-2008, 01:38 PM
:bsflag:
haha ok...
concordcobra
04-14-2008, 06:04 PM
yeah i know. I actually ran a 12.9@119 once haha
i gained 32 MPH after the 1/8
Nismosil40zx
04-14-2008, 10:09 PM
What boost was the cars on...
Digger_228SC
04-15-2008, 10:22 PM
That's really, really impressive !!! Now just a little work on the reaction times and you'll be deadly.
MMShaggy
04-16-2008, 03:18 PM
I'm the exact opposite, my truck is setup for 1/8th mile, so I fall flat on my face as soon as I pass the 1/8th.
nice times.
Work on reaction time and hes deadly? reaction time only matters in bracket racing, it has no affect on your ET's...:D
Digger_228SC
04-20-2008, 09:19 PM
Actually Shaggy, that's not true. In the case of his time slip above, his reation time sucked but that may not have been all his fault. Reaction Time = Vehicle Reaction + Driver Reaction and Driver Reaction typically =.250 out of the standard perfect.500.
Reaction time and ET are directly proportionate to stagging depth. The distance between the pre-stage and stage photo cells is 7-1/4". If you shallow stage your reaction time will be slower but you ET will be quicker because you get a running start (roll out). If you stage deep, your reaction time will be quicker and your ET slower.
When you go to the track, watch how we stage. We use what is known as bump stagging. We go into the first light, stop then bump ever so gently into the second bulb. We want it to flicker on. 2 reasons. We want to be in as shallow as possible to set up the delay boxes consistantly and if you stage in the exact same spot every time you get deadly consistant. The only way you can judge that you are staging in the exact same spot every time is to bump stage.
If you want to increase your roll out (for better reaction times) increase the circumfrance of the front tires by adding air in 10 lb increments. Or if you're red lighting vise versa and let air out.
Digger_228SC
04-20-2008, 09:26 PM
Also, by the way. Drag strips assume the .500 on a sportsman tree for reaction times so the .218 on his time slip was actually .718 from the last yellow or .218 from the green. The driver reaction time I discussed above is in the assumed .500 between the last yellow and the green. Even footbrake racers need consistant reaction times below .050. Trans brake racers need consistant reaction times of .020 (on the high side) if you expect to go rounds.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
