View Full Version : orange peel
DI$N3Y
03-30-2008, 07:51 PM
hey guys my friend just painted his car and it has lots of orange peel. the guy that painted the car said he used like 4 or 5 cots of clear, i will like to know if wet sanding and buffing he will be good ??????
help plz
oldschool98
03-30-2008, 08:24 PM
Thats a lot of clear at one time. Sand and buff if you know what your doing. If you dont....well, you know.
DI$N3Y
03-30-2008, 09:22 PM
yea someone professional will wet sand and buff but i just wanna know if the orange peel will be gone
Colonel Mustard
03-30-2008, 09:25 PM
peel is in the base/color....wetsanding won't help
oldschool98
03-30-2008, 09:30 PM
Some of it but clear will peel badly if sprayed wrong.
DI$N3Y
03-30-2008, 09:35 PM
oooh thats what i wanna to make sure of thanx
Hellfire_Studios
03-30-2008, 10:02 PM
retard quote of the day.
If you find some one that knows what they are doing then they should be able to fix the mess. I would go ahead and tell you what to do but then I would have like 15 people that think they know what they are talking about that would say I am wrong. Ah...the beauty of TR paint / body forums. I can give you some pointers if you want to PM me.
There are many different ways to fix your problem. Don't get discouraged.
Josh
oldschool98
03-30-2008, 10:20 PM
Josh
Didnt understand the" base" peel thing either.Just didnt want to lash out.:lol:
351coupe
03-31-2008, 10:49 PM
peel is in the base/color....wetsanding won't help:roll:
Ncotignola1
04-02-2008, 10:42 AM
exact same thing happened to my car bought it with that MAKO SPECIAL lol and took it somewhere had it wetsanded and buffed and besides maby around some of the edges u would never be able to tell it was mako the orange peel goes away but be carefull ive see people sand too much and some of the sanding marks have remained visable even after buffing
christo4_99
04-03-2008, 10:59 PM
keep your paper clean...1500 and 2000 grit don't usually scratch the paint,but a fart chunk from a rats ass will...that is to say "anything" ...dirt, sand,a pretty hard booger,a hair...almost anything will scratch the paint.
MadeAStinky
04-07-2008, 10:21 PM
watch out for solvent pop with that much clear as it cures it could still pop even a week after painted ive seen it happen
jdm2474
04-08-2008, 02:17 PM
the orange peel is in the the clear not in the base unless its a single stage painted wrong.if u have 5 coats of clear all u need is a wet sand and buff.
ONE MORE THING IF U GONNA TAKE ADVICE TAKE IT FROM OLD SCHOOL HES THE ONLY ONE ON HERE THAT KNOWS WHAT HES TALKING ABOUT.DONT KNOW HIM BUT HEARD NOTHING BUT GOOD THINGS ABOUT HIM AND HIS INFO IS TOP NOTCH
junpower
04-08-2008, 03:32 PM
Here is a picture of some wetsanding and polishing.
There should be no Scratches left over.
It takes many steps and 3 diffrent sand papers to cut the peel down nicely.In the QP pictures you can see the polishing in comparison to the B pillars.
Hellfire_Studios
04-08-2008, 10:16 PM
hit it with some 80 grit ;)
oldschool98
04-09-2008, 09:25 PM
Hold on there killer. I appreciate the compliment, however, There is much more experience and talent on here than I can deliver. I get lucky sometimes, but remember even a blind squirrel finds a nut every now and then. ;)
clean teg
04-10-2008, 05:57 PM
Plus 1 For Grady
D00MSB08
04-19-2008, 03:59 PM
4-5 coats of clear. if layed out right.that is plenty of clear to take down that orange peel with 1500/2000. when a compound buff/foam glaze. you should be good.
Hellfire_Studios
04-19-2008, 07:00 PM
wow thats alot of clear. You should really be able to do it with 2-3
Josh
jdm2474
04-22-2008, 11:50 AM
Josh
thats a right and wrong ? reason being it depends on how thick or thin the painter lays the clear down but on the other hand ur right a good 2-3 layers should be enough.theres a body shop in saftey harbor were my old shop use to be and he uses half a gallon up to a galllon of clear for the show cars he paints, even hondas
jdm2474
04-22-2008, 11:53 AM
i hear you but still i double check all your info and your on point so double bump for oldschool even tho i dont know him lol
obituary
04-25-2008, 03:52 PM
sprayed with too much air pressure ,that causes orange peel
Hellfire_Studios
04-25-2008, 06:52 PM
Im glad I am right and wrong.....I have only painted a few cars :roll:
RB240Mike
04-29-2008, 01:52 PM
haha wow, you know nothing about painting do you?
orange peel is when you are spraying clear on thick and the gun is to close to the surface you are painting.. thus the air coming out of the spray gun makes slight ripples in the clear.
wet sanding and buffing will take everything out, just dont start wet sanding under 1000.. preferably 1500 then work your way up to 2000
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
