PDA
View Full Version : need help a.s.a.p
a&r2008
03-27-2008, 03:16 PM
my chrysler lhs 97 is overheating what can it be and how hard is it to take out the radiator
Chris RX-7
03-27-2008, 03:34 PM
Check your belts... If a belt fell off your going to overheat. Then check that there is fluid in your reservoir , the radiator lines for any leaks, and make sure your thermometer isn't fried... If your leaking from the radiator then you need to change it. As for the difficulty of changing the rad, it's not that hard just a messy bitch to do... ALWAYS check the cheap shit first when diagnosing a problem so you don't spend hundreds of dollars trying to fix something that could have been solved with $8 and a trip to autozone.
Dano Moparo
03-28-2008, 09:42 AM
Could be a number of things. Cooling fan relays and motors are common failures. There is also a harness at the bottom of the cooling fan assy, some people call it a module, some call it relays, but anyways that harness is also a culprit.
Like Chis posted, check the cheap and easy things first before spending a few hundred on a radiator your not sure you need.
TURACE24
04-14-2008, 01:34 PM
Ive also had alot of problems with thermostats on those vehicles, partially sticking or sticking closed. if it is a 3.5 engine that is.
mogo21
05-09-2008, 03:30 AM
Prob head gaskets those things are infamous for that little costly trick.
EnsenCorp
05-21-2008, 08:14 PM
Junk it. I'll give you tree fitty for it
Jetflat&tripleBlack
05-22-2008, 11:30 PM
Id start with the fan, then once thats out id take the rest of that pos to the boneyard.
