PDA
View Full Version : DOM tubing
RoadRacer
03-26-2008, 10:08 PM
Does anyone know where I can get 1.75" x .095" Seamless mild steel (DOM) tubing?
Thanks
ChrisN1313
03-27-2008, 01:05 AM
Thanks
I got some from ART today but it was a tad bigger like .120 Give them a try they should have it
BLUE2KSS
03-27-2008, 03:02 AM
ART carries 4130 if you are looking for that
you might also want to check Metal Supermarkets in downtown tampa. I am going to be picking up some 1.75" .120 tomorrow actually for a jig for our axle to be heat treated
ChrisN1313
03-27-2008, 07:58 AM
that or Alro Metals on 49th street. They will have it for sure.
RoadRacer
03-27-2008, 10:14 AM
Thanks for the info, I will try alro and Metal Super Market.
ART doesn't carry DOM.
If I can't find DOM, then I will probably use CroMo from ART.
ChrisN1313
03-27-2008, 02:10 PM
Thats funny I just bought a nice chunk of it yesterday from ART. :lol: Maybe I bought the rest of it
RoadRacer
03-27-2008, 02:29 PM
hmm, I called earlier this week and they said they only sell ERW, not DOM.
I have an ART cage in my car right now, but the new car I am building needs DOM tubing to be legal in order to run with NASA.
I will call ART again. Thanks for the info :thumbup:
Mars_302
03-29-2008, 01:41 AM
how do they know the different anyway betten seam welded and drawn over mandrel especially after its all painted? You sure .095 is legal? Thats pretty thin unless its C/M. The stuff in my bar is .130 and its beefy but ERS
rpm motorsports 2
05-23-2008, 06:14 PM
TRY EAGLESNEST RACING IN CLEARWATER 727-536-1202 tHEY BUILD ALOT OF THE MOD MINI OR PRO 4 CARS IN THE AREA. THEY SHOULD HAVE IT.
norachelhere
05-25-2008, 03:30 PM
sub'ed for future reference...
RoadRacer
06-05-2008, 10:45 PM
I found DOM
Jimmy Cope Racing off of 49th St N in St Pete has .095 DOM, which is usually used in cars up to 3000 lbs. He also has a mandrel bender.
norachelhere
06-05-2008, 10:55 PM
thats cool. So you just buy straight lengths and the bends and weld it all up yourself, right?
treekiller
06-06-2008, 02:21 AM
Not for most sanctioning bodies. many will will require AT LEAST the main hoop to be of a single unbroken bar bent to fit the confines of the chassis.
you want the LEAST amount of welded in bends as possible. go grab a rule book for any sanctioning body, almost all of them are available online. the rules usually specify a diameter and thickness and number of points for your given class/weight.
Good Luck
Jeff Lloyd
RoadRacer
06-06-2008, 10:42 AM
Jeff is right. The main hoop has to be one continuous bar with bends, so you can't weld straight pieces to 90 deg bends. The welds have to be top notch with full penetration. There are many rules to building a legal cage (SCCA and NASA), so get a rule book before you spend the time and money on a cage.
If your car is under 3000 lbs 1.75" x .095 DOM should be fine. If you use ERS the wall will have to be .122 because it isn't as strong as DOM. BUT, SCCA and NASA won't allow an ERS cage to pass tech, unless it was built and accepted into the cars log book before 2003.
If you are going to do any competitive racing, build a DOM cage.
norachelhere
06-08-2008, 07:10 PM
I knew the main loop had to be one solid piece (i'm assuming with one weld)
I didn't think the rest of it would be a problem....
I'll have to find some rule books and find out... The original idea was to build a cage/chassis for weight and suspension.... but it might as well be legal if we're gonna do the work right?
