Help identify noise
Old Mar 26, 2008 | 09:53 AM
blkackteg's Avatar
Now with more c5!
Default Help identify noise
I've been intermittently getting a squeek squeek sound seemingly comming from my drivers side front wheel at around 35-40 mph. The faster I go the more the noise becomes a constant squeel and the louder it becomes. At 60+ it is extremely loud. The sound is made whether in gear or netural and the application of brakes or lack thereof doesnt affect it.
I have reciently changed the all rotors and both axels before first noticing the noise. After the noise started, I have also changed the hub bering in the front drivers wheel.
I cant find anything rubbing. It is not a tire clearance issue. Any thoughts as what else to check?
Old Mar 26, 2008 | 11:14 AM
dscivicdx's Avatar
TR Balla Donor Supreme
is it a squeal or something scraping?
if is more of a scraping, check the rotor dust sheilds and see if its contacting the rotor.
Old Mar 26, 2008 | 01:49 PM
casanova1514's Avatar
civic97
+1 have done this myself u by accidently bend the dust sheild to close to the rotors thus creating a really loud noise just cock ur whell stick u hand back thier while the car is cold ... hot rotors and hands = ouch.. and bend towards the motor should fix prolbem, let us know bro
Old Mar 26, 2008 | 02:19 PM
Outkasted24's Avatar
** I ♥ Old Skool **
what vehicle is this in?
My Flickr
slam.poke.drop.tuck.dope
Old Mar 26, 2008 | 03:50 PM
blkackteg's Avatar
Now with more c5!
The dust shield didnt appear to be touching, but I pushed it back again today anyway and it didnt help. It seems more like a squeling than scraping anyway.
The car is a gsr.
I'm pretty stumpted.
Old Mar 26, 2008 | 03:58 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
ball joint??? If the boot is broken, It will dry out therefore making said squeeky squeek sound...Happened to me
www.jdmmindz.com
Lurkin' in a hood near YOU!
Thatguysstuff's Avatar
Hey its that guy!!
Sounds like a crappy wheel bearing...
did you get it pressed it?
Old Mar 26, 2008 | 04:00 PM
Mr. Stealyogirl
A wheel bearing doesnt squeek, Not any i heard, It roars and shakes.
www.jdmmindz.com
Old Mar 26, 2008 | 04:06 PM
unique intensions's Avatar
+1 Ball Joints squeek alot when busted. That shit will continue until you replace it. I would check the upper ball joint but if you need to replace you are better off replaceing both sides as well.
