lots of stuff for sale. mk2 and mk3 supras
Contact Information
Home# 813-810-6038. i will not answer when im at work. prefere pm
Office# n/a
Cell #: n/a
Email: williamb82@yahoo.com
Pm: Yes
Asking Price: diff for each part. see item description
7mgte electronics stuff for sale. the full engine harness, only 1 broken plug, its the injector clip plug on the thermostat housing. everything else is good. it is a 87/88 harness. i also have the 5 speed ecu, tps, cam sensor, coil pack, the plugs from behind the dash, the 6 pin yellow plug by the fuse box, an afm, though the afm isnt pretty it still works. it is the one i had sent to the guys that make the maft. he removed the lid to be able to check the calibration etc and siliconed it back on. i do not have the fuel injector resistor. forgot to pull it. also will be including the knock sensors and the injectors, also the 02 sensor. this would be good for someone that bought a jdm 7mgte etc...
asking $300 + shipping for the stuff. only thing mising is the fuel injevtor resistor
84+ 5m afm's i have 2 of them left. $25 each + shipping.
stock mkii brake calipers. $10 each + shipping
7mgte exhaust manifold. older style without the reinforcing ribs. $40 + shipping.
louvers. black. local pick up only. i dont know the brand name. they were on my blue 85 when i got it. $50. pick up only.
stock mk3 front brake rotors. $20 + shipping for the pair
stock mk2 front brake rotors $20 + shipping for the pair
stock mk3 7mgte downpipe. $10 pick up only. flange to cat has been cut off iirc.
mk3 mid sump oil pans. $20 + shipping.
ford edis 6 ignition module with the vr sensor. includes the pigtails for both. $50 shipped. witht he coil $80 shipped. used for megasquirt setups.
bolt on crank trigger wheel for the edis ignition use on a megasquirt. $75 shipped.
rear mkii springs $10 + shipping SOLD!!!!
82 5mge upper and lower intake manifold, with the funny cold start injector thing and throttle body with tps $30 together + shipping
291 sbc camel hump heads 2.02 intake, 1.6 exhaust valves, no accessory holes, 64cc combustion chambers. they have been polished, possibly ported. dont have gaskets to match up. umbrella style valve stem seals. both heads have 1 chip though, same bolt hole on each. the pics show it. these as i was told came from a 68 camaro z28 with a 302 sbc in it. $300 o.b.o for the pair + shipping.
williamb82/heads - Photobucket - Video and Image Hosting
im trying to clean up and reorganize my storage unit so if you need pics lmk and i can prolly get them saturday.
Office# n/a
Cell #: n/a
Pm: Yes
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
bump. still got tons left.
bump. louvers are supposed to be sold today, but till they are paid for they are listed.
yup, louvers are sold. lol
