omgosh
03-19-2008, 01:27 AM
I've got some terrible interference in my stereo....here's the story.
I was going 70 or so down an off ramp blasting some tunes, and my amp came unbolted. I believe it shorted itself out on my other amp..So anyway it made some pretty loud static and I immediately turned off the radio. I got home, reconnected it (ground was loose), and now I have this awful alternator whine coming from the REAR ONLY among other things. Here is a list..
-alternator whine
-still noisy with motor off
-speakers hit when any light turns on (dome, headlights, fogs, whatever
-I can hear my fuel pump and e-fans through the speakers
-sub hits when motor is powered down (I've heard this is normal but it never did this before.)
setup:
-kenwood hu powering front speakers
-4(2maybe?)ga power /grounds w/inline fuse
225 watt bazooka amp powering 8" tube
180 watt 2-channel powering 2 Pioneer 6x9 3ways
what I've tried already:
-moving ground
-adding grounds
-redoing engine/chassis grounds
-new RCA cables
-new amplifier
-grounding RCA outer shield to chassis, also to amplifier ground in trunk
-ground headunit to chassis, also to amplifier ground in trunk
-disconnected and reconnected everything like 3 times.
The ONLY way I can get rid of the noise is if I run the RCA's off of the front speaker pre-amp instead of the subwoofer/rear pre-amp. I don't want to do this, nor do I know why the fuck this works. Did I blow out the pre-amp somehow? Is this possible? The headunit works fine otherwise...
I'm stumped, unless my headunit is in fact broken. I have no spare to test it with :( If anyone has any insight it would be greatly appreciated.
-alternator whine
setup:
-moving ground
-adding grounds
-new RCA cables
-new amplifier
