PDA
View Full Version : Chevy 3800 Coolant Draining
wksracing
03-17-2008, 06:20 AM
Does anyone have a suggestion as to how one may go about draining off a certain amount of coolant in a Chevy 3800 engine, so as to facilitate the removal of the drive belt tensioner.
The car CANNOT be started nor can it be moved. The coolant must be drained (partially/fully) in order to remove the tensioner. Any suggestions would be appreciated.
Thanks.
corey r.
03-19-2008, 03:22 PM
open the drain on the bottom of the radiator?
wksracing
03-19-2008, 11:40 PM
You are correct Corey......that was the easiest way.....thanks.
