PDA
View Full Version : Attention Wayne Garris
91Notch
03-13-2008, 10:56 AM
2006 Ford Mustang V8-4.6L VIN H
Vehicle Level (http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OD~N/0/115013665/117095347/117099978/117099982/34853741) http://www.motor*******.com/images/a_003366.gif Transmission and Drivetrain (http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OD~N/0/115013665/117095347/117099978/117099982/34853741/34860071) http://www.motor*******.com/images/a_003366.gif Automatic Transmission/Transaxle (http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OD~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072) http://www.motor*******.com/images/a_003366.gif Service and Repair (http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OD~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183) http://www.motor*******.com/images/arrow1.gif Transmission Fluid Drain and Refill Without Torque Converter Drain Plug (http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OD~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371) http://www.motor*******.com/images/arrow2.gifhttp://www.motor*******.com/images/blnk_spc.gifTransmission Fluid Drain and Refill Without Torque Converter Drain PlugNotes (javascript:notesWindow('http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OF34~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714'))Transmission Fluid Drain and Refill Without Torque Converter Drain Plug
Special Tool(s)http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658799
Materialhttp://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121631166
NOTE: Left side of case is shown.
Fluid Fill Referencehttp://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658792
Draining
With the vehicle in NEUTRAL, position it on a hoist. Set the vehicle as close to level as possible. For additional information, refer to Vehicle/Application and ID
Remove the drain plug (large plug) and allow the fluid to drain. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658785
Filling
Install the fluid drain plug.
Tighten to 26 Nm (19 ft. lbs.) . http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658786
Hold the larger drain plug with a wrench and remove the small (center) fluid level indicating plug. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658787
Install the special tool into the pan. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658788
NOTE: Prior to filling the special tool with clean transmission fluid, make sure that the canister is clean. Fill the special tool with clean automatic transmission fluid. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658789
Hang the special tool under the vehicle, upright and close to the transmission. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658790
Connect the special tools.
Connect the open end of the fluid hose from the Fluid Transporter/Evacuator/Injector to the Adapter, Fluid Level and Fill Plug at the bottom of the transmission fluid pan. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658733
Apply a maximum of 206.85 kPa (30 psi) to the open end of the vacuum/pressure hose from the special tool. Fluid will immediately start flowing out of the special tool into the transmission fluid pan. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658734
Add 2 or 3 quarts of transmission fluid into the fluid pan. Stop the process by releasing the air pressure and removing the air nozzle from the end of the hose.
NOTE: Engine idle speed (http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OD~N/0/115013665/117095347/117099978/117099982/34853741/100411974/34853743/58948512) is approximately 650 rpm . Start and run the engine until the transmission fluid temperature is between 27°- 49°C (80°- 120°F) .
Inspect the fluid level in the special tool. If the fluid drains back into the canister, the transmission is full. If no fluid drains back more fluid will need to be added. Repeat Steps 8 and 9.
Once the transmission is full, place a hand vacuum pump on the open end of the vacuum/pressure hose of the special tool and apply vacuum to the system. This will pull out any extra fluid trapped in the system and direct it into the container. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658784
Allow the fluid to drain. When the fluid comes out as a thin stream or drip, the fluid is at the correct level. http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658769
Reinstall the small (center) fluid level indicating plug using a 3/16-inch Allen key.
Tighten to 10 Nm (89 inch lbs.) . http://www.motor*******.com/*******/MOTOR~V80458083~C41686~R0~OB0~P3R0H~N/0/115013665/117095347/117099978/117099982/34853741/34860071/34860072/34860183/124234371/121811714/121658770
