PDA
View Full Version : need help
celi-cuz
03-08-2008, 12:19 AM
i found a 4 cyld fwd engine and i cant get any info on the #'s off of the block. E 4ak73 10 14 b1 .83. if anyone has any info that would be sweet. thanx
importedhp
03-08-2008, 11:10 AM
Was it in a car? Or does it have a intake manifold?
hachibill
03-08-2008, 01:32 PM
yeah, more info is needed, just tell us what year make the car was and we might be able to tell you what engine it is.
celi-cuz
03-08-2008, 03:50 PM
I have no clue what kind of car it came out of. yes it does have an intake manifold. and it is fuel injected. are there any other #'s that i need to try and find on it?
hachibill
03-08-2008, 03:59 PM
its a 4afe. prolly out of a 90's corolla or celica.
celi-cuz
03-08-2008, 04:09 PM
the guy said it was a 20r but i was jus wantin to double check. beacause im wanting to build my cellica up and wanting to run a turbo. it came with the 2200 efi engine and after doing a lil research ive found that the 2200 isnt a tuner motor with alot of potential
importedhp
03-10-2008, 12:23 AM
Yeah the 2200 is the 5sfe. Not good with performance. I think the 20r is a rear wheel drive motor which will not work in any celica a 5s came in. Your best bet is to get the 3sgte clip either from an alltrac or mr2. What yaer Celi do you have?
Whats up Bill? Hows life treating you?
hachibill
03-10-2008, 11:03 AM
good, moved back the the tampa area. orlando sucked.
importedhp
03-10-2008, 09:51 PM
Sweet! We all need to meet up some sat night again.
celi-cuz
03-12-2008, 03:33 PM
its a 1990 gt
hachibill
03-12-2008, 03:45 PM
like i said its a 4afe. look at the 1st numbers and letters on the block. it starts with 4a, if it was a 3s or 5s those would be there instead of the 4a.
celi-cuz
03-12-2008, 06:16 PM
ok thanks alot man
importedhp
03-12-2008, 11:49 PM
Well if the intake manifold says 2200 efi the that is the 5s. Does the motor stand straight up ( 4afe) or slant back towards the fire wall (5s-fe) Also you can look undr the hood and the info sticker and on the lower right corner i beleave it will tell you the engine code. 90-93 celica gt only came with the 4a or 5s engines. I have a gts which only came with the 5s. Where are you located at?
Alltracfreak
03-16-2008, 01:30 AM
you can put 88 gts on the 5s motor and it would be a lil bit more powerful intake mani is the main problem though
celi-cuz
03-16-2008, 04:19 PM
the 2200 is in the car now and the 4a is sittin on the floor in my friends shop so i dont know if it sits strait up or tilts like the 2200
hachibill
03-17-2008, 10:32 AM
the 4a site strait up, only the s series motors are tilted
importedhp
03-19-2008, 11:33 PM
Oh I wasnt follow I guess. Didnt realize that you had 2 motors. My bad Bill wasnt tested you Knowledge. Just confused. As far as doing the swap to a 4a. Dont know much about it.
hachibill
03-21-2008, 07:33 PM
no biggie, i hope you got all the info you were after.
