View Full Version : Expert advise
Rx7_guy
03-07-2008, 12:13 AM
Im going to painting my car...im not looking for show quality.
I understand that my compressor is not great for use with an HVLP..
I have a 2hp 33 gallon tank...but could I get away with painting a section at a time?
I get about 8 cfm @ 40 psi.
The gun uses 7cfm
thanks for your help..
oldschool98
03-07-2008, 07:26 AM
You might get a fender sprayed before you are out of air. Thats a small compressor.
IThaJokaI
03-10-2008, 06:52 PM
a 33 gallon tank with only 2hp is quite small.. Although its not a small tank. And you have to look at what CFM the gun uses at what pressure... You say you have 8cfm@40psi which means its even lower at 90psi which is what the gun should require. You could paint small areas at a time but Im not sure how the coverage will be with that CFM rating...
jlmaxima4sale
03-10-2008, 09:02 PM
honestly you will be fine with that and shouldnt run out of air at all as long as your cfm on the gun is lower then the compressors .... a hvlp requires about 10-15 psi to run so 8 cfm at 40psi is plenty .... I spray my clear with a gun that takes up 9.6cfm and the compressor i use is 10cfm @ 40psi and i shoot the clear at 40-45psi and never have a problem even on a all over job....
Content Relevant URLs by
vBSEO 3.2.0 RC5
