PDA
View Full Version : The Big Three
USFBULL69
03-05-2008, 08:36 PM
I started my big three upgrade today. Was only able to get one wire done, the one from negative battery to chassis. I am going to do the engine to chassis wire tomorrow. and the one from the alternator to battery positive is going to be a pita because im doing this in a ford escape. I can already tell a slight difference in the vehicle,as far as the brightness of my lights. This should be a simple upgrade for anybody to do.
USFBULL69
03-05-2008, 10:12 PM
i will try and post pics up. The next wire I am doing is the one from the engine to chassis. It is easily seen in my engine bay on the passenegr side. The alternator wire is gonna be fun becaus ethe alt. is located at the rear bottom part of the bay.
kpr10is
03-06-2008, 12:59 AM
You're going to spend as much time taking out and putting away tools as you are actually doing the install, the big three shouldnt take more than a half hour in a difficult car. But whatever works for you. My alt. is pretty far down too...wratchet extensions and long arms work though, at least in my car, but prepare to get your arm dirty if youre reaching down. Good luck, you should see noticeable results.
USFBULL69
03-06-2008, 06:23 AM
i would have but i checked out my battery connections and the bolt for the negative terminal had stripped and was not making a tight connection. so i went out and bought a new one. I had to cut the old one off and put it into the new one.
PŘ57
03-06-2008, 07:34 AM
no need for pics. Most of the real car stereo guys do these already. :D
Notladstyle
03-06-2008, 05:58 PM
no need for pics... that would only make an inordinately simple task more complicated.
TBSpyder
03-07-2008, 02:40 PM
You guys are dicks. Let him take pics, I'm sure there are people on here who could be edumacated by it. Not everyone is an elite professional car audio installing guru like yourselves.
PŘ57
03-07-2008, 02:42 PM
My post's intent was lighthearted banter. Dalton was the one that took it two steps over. :mad: Don't pit me in with him.
TJElite
03-07-2008, 03:04 PM
For the engine to chassis connection, you might want to use several smaller wires (like 8 ga.) from different parts of your engine. Several of the horsepower mags have tested this, and found between 3 and 10 hp. The concept is that it gives good grounds to your sensors...they typically run on 5v signals, so a good ground makes them more accurate.
Toby
djgizmo
03-10-2008, 03:15 PM
...Let him take pics, I'm sure there are people on here who could be edumacated by it. Not everyone is an elite professional car audio installing guru like yourselves.
+1
Notladstyle
03-10-2008, 06:31 PM
Yeah don't lump me with him, hes not a car stereo guru... and im not an asshole.
PŘ57
03-10-2008, 08:22 PM
plus one
norachelhere
03-10-2008, 09:16 PM
Toby
yeah, I think the horsepower gains might be a little flawed, but it does make it run smoother. A good ground right next to the ECU makes a pretty big difference too instead of it grounding out all the way back to the battery like usual.
I do agree though that multiple engine grounds work better than one main ground...
