PDA
View Full Version : TESTING one of our LHT intercoolers !!!
MrLHT
03-04-2008, 03:55 PM
This is a intercooler and piping for a Subaru Lagacy with fog lights. there's lots of bends to clear everything and fit the car perfect. Just to make sure it's 100% we did a leak test, we filled the system with water and made a quicky connector to join the trubo side to the intake side to seal it. We then pressurized it to 40psi to make sure there were no leaks.
It passed the test, but we figured while it was hooked up we would crank up the air pressure a little .
All the piping is tig welded and bead rolled to prevent blow off.
You get the very best when you choose LHT to build your intercooler piping.
Below are the pictures, I'm the one(John) holding onto the piping and Paul taking the pictures for a safe distance incase it turns into Waterfest in the shop.
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01545.jpg
http://i89.photobucket.com/albums/k231/lhtperformance/DSC01548-1.jpg
You can be sure an LHT intercooler pipe will not blow off.
jlude90
03-04-2008, 04:12 PM
good thing nothing happened, that is REALLY dangerous like you said
but its good to know you guys actually test like this instead of so many other guys who just make stuff and hope it works
noh22forme
03-04-2008, 07:23 PM
holy shit
iamboon
03-04-2008, 10:46 PM
Thanks John and Paul, you have a great reputation and your work is flawless! I will be posting on the LegacyGT forum and I am sure my GT30R turbo will love this new set up! btw the avatar is my oldest son... he just won the World Brazilian Jiu Jitsu Championship title which is the largest BJJ tourney in the World.
If you want to remove the fog lights to use as air induction you can...I never have them on.. it may work for the passenger side to allow more air flow. your call.
Thanks for trying to fix my air-to-water set up.. if I was going to the track more and had a larger budget it may have been a good route to have you completely rebuild but for daily driving your FMIC set up will be much more efficient. Thanks again!
iamboon
03-04-2008, 11:19 PM
John what is the core dimensions of the FMIC? also people are asking on the LegacyGT forum for price.. can i give them a range or just have them call you?
MrLHT
03-05-2008, 07:58 AM
Well, We spent some extra time to make the piping fit around your fog lights, so we will not have to remove them. "Make the piping fit the car, not car fit the piping"
I will be in conact with you very soon , Just waiting for the carbon fibre.
iamboon
03-05-2008, 08:15 AM
thank you - its going to look sweet when all done! maybe my car will make it into some turbo magazine ;-)
iamboon
03-05-2008, 04:28 PM
John, can i stop by the shop tomorrow afternoon to take a few pics of the set up.. some more request came in from the LGT forum.. let me know thanks
djerickd
03-06-2008, 12:27 AM
nice work, I still need to get out there and check out the shop
iamboon
03-06-2008, 08:33 AM
from what I have seen a very clean shop even with all the projects going on inside..
homemade wrx
03-06-2008, 11:44 AM
nice and small precision intercooler...their cores are quite nice...and to think diesel boys actually run their trucks with more boost than that gauge is reading ;)
MrLHT
03-06-2008, 10:26 PM
I run the same exact size in my Type R, there fantastic intercoolers.
iamboon
03-06-2008, 10:40 PM
check out pics here
http://www.tamparacing.com/forums/subaru-tech/469128-my-new-fmic.html#post5188255
LHT Performance does beautiful work. I was not expecting such high quality work and attention to detail. Even though Snowman, Im Slow and Scott Johnson recommended and all stated LHT Performance did great work I was not prepared to see my set up done so professionally. Thank you John and Paul!
